Question about Sony Playstation 3 (PS3) Console
I tried the 3 beep thing but my controller did not connect so i turned it off an on again an now the screen is black an if i try the 3beep thing now it just goes back on stand by can you help?
    Scholar:
  • 34 Answers
Hi Loubrillet,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Posted on Apr 05, 2011
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
My Ps3 wont load the dashboard help
Please try the following solution to fix your PS3. Please note, option 5 will erase your hard drive so any save games you had will be lost.
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. If it still does not work try the above but choose option 4. If that does not work try option 5 as a last resort, this will erase the hard drive.
Once you have completed the above, the Playstation 3 should restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
I can hear my Ps3's Sound, when the HDMI cables are connected, and it's on the correct HDMI channel, though i can't see anything, the screen is just black. I have tried holding the power down, until i...
Ok, you are actually holding the power button down for too long. Please do the following to sort out the display on your PS3.
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again about 5 seconds later. Release the power button when you hear the second beep. The display will now reset and it should detect your HDMI display with no problem.
Hope this helps
Dec 23, 2010 | Video Game Consoles & Games
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
My PS3 freezes while playing both discs and demos. Occasionally it won't even recognize that there is a disc in the drive until I eject and put it back. When I click on the disc icon (tried with both...
You need to RESTORE FILE SYSTEM on your ps3.
Here is how you can do it.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 19, 2010 | Sony Playstation 3 (PS3) Console
All the connections work the ps3 comes on but then goes black
You may have messed up the Screen-Settings, to solve this try this.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
Oct 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
The laptop is not working and when it is turned on it has a beeping noise
There are different types of beep called POST beeps.
This informs that what the problem is on booting the system.
As per your concern I think it will be along beep 3-4 seconds long, and continued again and again, if this is your case then your RAM might be faulty or it is not connected properly.
To fixed the problem, re-connect your RAM and try,you should also try to boot with another RAM.
Thanks
Iqbal
Mar 24, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
139 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
