Question about Amcor Dehumidifiers
Where can I get a stopper to stop the water coming from the continious exit pipe and divert it into the water tank on my Amcor SD10 dehumidifier
    Brigadier General:
  • 4,736 Answers
Sorry it's taken so long for someone to respond to your question. The reason may be, that it's not very clear to us, what exactly you're trying to do. I think it's the part about "the water coming from the continuous exit pipe" and why you would want to run it into the dehumidifier tank?
So, if you could explain the specifics a little better, we may can help you.
Thanks
Posted on Apr 05, 2011
Can I get a replacement water tank
Yes you can if hot water tank you will need to go file for a homeowner permit and pay a fee and after you have installed you will need to call plumbing inspection to come to inspect
Jan 25, 2015 | Amcor ALD12000M 12000-BTU Portable Air...
Amcor dehumidifier repair
Is the motor working in it alright? Or does that make a sound also? That might be your problem.
Jan 02, 2013 | Dehumidifiers
Have had the unit on for 24 hours now & the water tank has remained empty all this time. Any ideas on this Amcor Dehumidifier dc100 ?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 21, 2011 | Amcor AHD65 Dehumidifier
My Amcor AHD 45E dehumidifier sounds like it's running, but it doesn't extract any water
heatman101
Oct 13, 2010 | Amcor AHD45 Dehumidifier
AMCOR SD10 Dehumidifier, Need to replace the electric fan motor.
Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Dec 30, 2009 | Amcor Dehumidifiers
Amcor tc100 started to leak on the floor but is still working
Ive had same issue with this machine. i opened it up and cleaned the plastic channels leading into the tank. Dust can collect and block these channels, diverting the water onto the floor. This cleared that problem, but now the fan is not working, so im hunting for one going cheap...?
Jan 12, 2009 | Dehumidifiers
Dehumidifiers Logo
180 people viewed this question
Top Amcor Dehumidifiers Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
