Question about GE Microwave Ovens
Yesterday I was reheating a non metallic coffee mug of water in my GE Spacemaker microwave. When I hit the cancel button a weird pressure explosion of some sort occurred. The door came flying open at me and missed my face by an inch or two the pressure forced me backward and there was hardly any water left in the cup. It was very scary and gave me a whiplash sensation. How do I find out if I have now been radiated? I thought my heart was going to jump out of my skin and now my neck hurts. Plus I don’t know if the microwave is safe to use. I have looked up and read about this water eruption phenomena but can’t find anywhere that it has blown the door open on someone. This was unbelievable. I am fine except the stiff neck but this is too bizarre. You don’t know anyone still at GE that might know if my microwave is unsafe do you? I suspect it is fine and it was just the rare water eruption that caused the pressure.
  • GE Master
  • 9,098 Answers
Microwaves do not use or generate ionizing radiation, so there's no worry there.
A burn is the real worry, and it's good that didn't happen.
While rare, this can be pretty dangerous.
There's a very helpful and comprehensive article about this phenomenon here.
Prevention is as simple as putting a non-metallic straw or coffee stirrer in the container before you heat it.
Posted on Aug 08, 2008
Microwave worked this morning and now not.....made no noise just stopped heating.
HELLO.
The solution is to diagnose the magnetron as explained below.
* 1 Fill a mug with room temperature water from your kitchen sink.
* 2 Place the mug of water on the glass cooking plate inside the microwave.
* 3 Set the microwave on "High" for one minute and press "Start." You should hear the magnetron hum while it is working.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. The next step repair or a replacement of magnetron if the water is still cold.
Thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Magnitron does not go on unless i run the vent fan
HELLO.
The solution is to test the magnetron as explain below.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. Contact the manufacturer for repair or a replacement oven if the water is still cold.
Thanks
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Paper caught fire in microwave. microwave power
check breaker in your home electrical panel...make sure all are on
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sensor error
I had the same exact thing happen...I put in some popcorn, it wouldn't pop. The screen said "sensor error". I tried heating water, a piece of chicken...nothing would heat. I unplugged it, plugged it back in...nothing. The manual says to close the door and hit the clear/cancel button. I could have sworn I had done that, but my wife simply hit the clear button and it started working again good as new. Hope yours does the same. : ))
Jun 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Heating Handle more than Contents
This is because the mugs are not really microwave safe.
For a while they will work, but over time, some non-safe materials' characteristics can change with repeated heating.
Eventually someone will get a burn, and/or a mug will mildly explode into a few pieces.
I have personal and professional experience with this! *grin*
Aug 18, 2008 | Microwave Ovens
Model 140 (new) stopped heating
If that is a new appliance, I would call GE and ask them to give you a new one or get someone to fix it.
This microwave should have one year warranty.
Hope this helps.
Feb 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Microwave Buzzing
It is not safe. If a microwave oven cooks without the cooling fan running, then your magnetron will soon overheat and be destroyed. At our Web site, we have important safety information plus information on diagnosing and replacing door switches. Our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If it;s not a door switch, then it may be a problem (such as a bad relay) on the control board. We repair these nationwide for $32.50 postpaid in most cases, and you can find out more through that link, too.
Feb 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
