The flame is spluttering - Heating & Cooling
    Brigadier General:
  • 4,736 Answers
Without knowing exactly what type of heater you have, this is just a guess, that the sputtering you hear is the pilot light flame. In which case, the pilot is dirty and needs to be cleaned. If you can furnish more information as to the make and model number of your heater, I can help you more.
Posted on Apr 05, 2011
Testimonial: "Thanks for your information. I was hoping it was the pilot. It is an Evedure Brigadier"
  • 1 more comment
  • Rich Landrum Apr 05, 2011
    Glad I could help you. Do you know how to clean the pilot?
  • cass125 Apr 05, 2011
    No . I was going to look it up if I could find the booklet.
    Cass, you'll need to turn the heater OFF and let it cool completely. Once it has, remove the front portion of the heater's cabinet and you'll has access t o all the inner workings. If your has ceramic plaques, carefully remove them. Use a vacuum that has a hose and a brush attachment to vacuum all of the interior of the heater, including the burner(s).
    To clean the pilot, a can of compressed air with a straw nozzle (like you clean your computer with, works well). Place the tip of the straw nozzle just barely into the tip of the pilot and give it a quick shot of air. Now, look down the pilot from the tip and about 1/2 way down, you'll see a small hole in the side of it. That's the ODS Sensor. Place the tip of the straw nozzle just barely into it and give it a quick shot of air. That will blow any debris out the other side.
    And finally, reinstall the ceramic plaques (if your heater has them), reattach the front of the heater cabinet and you're ready to light the pilot and put the heater back to work.
    FYI - What you just completed doing was what's called "Annual Maintenance". You should do it every Fall, before firing the heater up for the season.
    Hope this helps you get it accomplished. Have a great day!
Car is spluttering
could be fuel pump in the tank you need to plug it in to a diagnostic machine
Mar 21, 2014 | 2001 Citroen Xsara
Dangerious engine splutter
Has anyone checked the fuel pressure, and has the fuel filter been replaced ?
Jun 25, 2013 | 1999 Chevrolet Blazer
I have a yz450f 06 and its not running right its spluttering and poping on take off and cruizing at low throttle.
clean plugs, is the smaller jet blocked. is vacuum pipe to tank leaking anywhere.
Mar 11, 2013 | Motorcycles
My diesel vw transporter misfires/splutters on
I have just had my T4 2.4 cambelt and water pump done but the van does not run right unless the choke is out any ideas?
Many thanks
Mark
Mar 31, 2010 | 1999 Volkswagen Euro
Running problem in monsoon season in Daewoo Matiz.
Has the clutch been replaced recently? There is an earth wire under one of the bell housing bolts,if not refitted can cause all sorts of problems.
Jul 19, 2009 | 2000 Daewoo Lanos
Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Feb 19, 2009 | Rangemaster 110 (Dual Fuel) Dual Fuel...
1998 Aprilia RS250 Still Spluttering
Hi and welcome to FixYa,
Your described problem could be the battery but I am also inclined to suspect the voltage regulator. If the 'splutter' is when revving/higher RPMs, then the CDIs are cutting off possibly because of higher than normal voltage from the regulator and/or the battery is not loading the system(charging). Try charging the battery externally for at least a couple of hours, try and observe. You can also have the battery tested. If the battery checks good, accepts a charge and the bike will run normally after being charged, then the regulator must be considered.
Good luck and thank you for using FixYa.
Feb 11, 2009 | 1998 Aprilia RS 250
I have a pit bike and it splutters alot when i ride it
my pit bike will not keep it revs for a long time so can some one help me it is my first pit bike
Jan 09, 2009 | Pit SSR 110CC Pro Beginner Bike
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Oven flame and gril flame do not increase from starter/low flame setting. grill flame also splutters. seems not enough gas not getting through.
HI thanks for your question. the problem with your gas oven, is the igniter is not hot enough to ignite the gas. a common problem with gas ovens. replace the igniters. thanks the appliance doc. please rate my answer, if happy thanks-
Oct 14, 2008 | Kitchen Ranges
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
