Question about Sony DCR-SR47 Camcorder
I have a sony Handycam (DCR-SR65) model, the battery is loaded but the camera won't switch on, it looks dead!
  • 58 Answers
Is the battery fully charged?
If you connect the camera to the charger same happens?
Try charging the battery or test with a different battery.
Posted on Apr 05, 2011
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
The solution shown by you is not sufficient. I need Software PMB for Sony Handycam DCR SR 65 on os XP SP2
Here is a link to the Sony site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DCRHC21&LOC=3
Clcik o n the Drivers link on the right side. Select your operating system from the drop down menu and the choices to download will appear near the bottom. Click on them to download to your computer.
Jan 10, 2014 | Sony DCR-SR65 Flash Media Camcorder
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
Sony handycam DCR SR65 HDD format error E31:00
Recently purchased a camcorder DCR-SR68 and we took all our wedding video on it. It now says HDD format error and all my video is gone. I tried resetting didn't work, took out the battery, didn't work. Sony told me to format the drive but that also not function. couldn;t format that.
Is it possible to recover this video??? can i solve that problem?
please send to solve that problem
Aug 09, 2010 | Sony Handycam DCR-SR100 Camcorder
My Sony Handycam DCR-PC9E mini DV Digital Camcorder is totally dead. Even powered the camcorder at Camera position and reset it according the operating manual. Yet there is no response at all . Is there...
This is a simple case of the Bat going dead, it does look from what I read that the Sony batteries do not seem to stand up long these days, I am hearing of this daily on the Mini Cameras, where my old faithful 8mm camera bat is 8 years old and as good as new.
Jun 13, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
Sony dcr-trv270e camcorder not loading the tape
problem resolved by .... 1... switching power off, removing battery and the after reconnecting battery power on + pressing the reset button on camera. This process done a couple of times.
2.. cleaner tape then loaded successfully.... ran this for a minute. 3.. camera now loading tapes as required.
Jun 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
I was lost CD driver Sony handycam DCR-SR65, please send the copy driver. t/q
Thank you of taking consideration of my problem.as today my problem was solve after i bought new CD driver.
May 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another...
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Apr 11, 2006 | Sony Handycam DCR-PC330E Mini DV Digital...
Sony DCR-SR47 Camcorder Logo
189 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
