Question about Smeg Dishwashers
I have a Smeg dishwasher which has worked perfectly up to this week. It now stops approximately 16 minutes from the end of the cycle and shows the error message E 8. I have unfortunately been unable to find the manual or code on the product to provide these details for you. I look forward to your reply. Many thanks
  • 822 Answers
Http://www.smegtech.com
check this out.... might help.........
some smegs have a reset button behind the plinth....
cheers
Posted on Apr 05, 2011
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Dishwasher does not complete the cycle
Repair guy came out and after an hour of taking things to bits and not finding a leak , we managed to identify the problem as originating from a faulty door seal at the top door lock ( it was ever so slightly dented in/warped) which had caused the water to track through the door lock down into the machine and trip the electrics after 30 minutes in the cycle. He'd never heard of this happening before - just my luck!!
Door seal replaced and ( so far) everything working fine.
Dec 30, 2008 | Smeg 24 in. DWD612SS Built-in Dishwasher
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Smeg DF612S
Check to make sure there r no kinks’ in the drain line or that it is not clogged it sounds like the sensor is tripping because there is too much strain on the pump just like a breaker.
Nov 07, 2007 | Smeg 24 in. DWI612 Built-in Dishwasher
Help
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Nov 08, 2006 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
439 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
