Question about Keurig B60 Coffee Maker
Was flashing descale and now only one button lights and produces minimal coffee.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Apr 05, 2011
How do I check the milk brother valve on my coffee machine
saphira? check the air nozzle on top of the cappu-outlet . if the machine indicates that you should descale, the cleaning cyclus wont work. to descale you have to turn off the machine by pressing the on-off button on the front side (behind the tea-and steam button). if the machine is turned off, press the descale button for 3 seconds. after the descaling cyclus you will be able to clean the machine.
Nov 05, 2014 | Franke Saphira Espresso & Coffee Maker
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
My maker keeps on saying descale. but how do i do it.
17.3 Descale
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the message:
DESCALE
flashes on the display, you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the P button (the light over the button comes on) then press the button repeatedly until the
appliance displays:
DESCALE No
• Press the button (corresponding to the SET symbol flashing on the display) and the appliance will
display:
DESCALE YES
• Press the OK button to start the descale programme.
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one litre of
water.
For subsequent descaling, use descaler of the same type and brand as supplied (available from technical
service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
34 C o l l e c t i o n
• press the OK button.Descaler runs off from the hot water spout into the container below.
The appliance displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
Oct 22, 2013 | DeLonghi Prima Donna Avante ESAM6700...
Water temp and descaling lights flashing
you need to descale the machine as per instruction
Oct 15, 2012 | Solis Palazzo Espresso Machine
Flashing dregdrawer and descaling lights
You need to run the descale process, which essentially cleans the plumbing.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
Same problem here. I've googled and see that there are many people with the same problem but no clues about how to solve it:
My Saeco Odea Giro is flashing two lights alternatelly (Dregdrawer Light and Descaling Light). What's the problem and how can I solve it?
Aug 10, 2010 | Saeco Odea Giro Espresso Maker -...
I have descaled my Saeco Odea and the coffee beans light and the descaling light keep on flashing from one to the other
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Dec 06, 2009 | Saeco Odea Go
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Oct 31, 2008 | Coffee Makers & Espresso Machines
Keurig B60 Coffee Maker Logo
186 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
