Question about Vivitar Vivicam 5105s Digital Camera
How do I switch off the date/time function - Vivitar Vivicam 5105s Digital Camera
How to set the date and time
Setting the Date, Time and Date Stamp:
Use the following procedure to change the date and time setting.
1. Slide the Function switch to the capture mode.
2. Press the Mode button twice to turn on function menu. Press the Shutter button to confirm.
3. Press (up arrow icon) or (up arrows icon) to adjust the date and time. Press ◄ or ► to advance to the next setting.
4. When finished, press the Shutter button to confirm the setting; press the Menu button to return to the main menu, press the Mode button to exit the menu.
Jul 07, 2011 | VistaQuest VQ-500 Digital Camera
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
Apr 26, 2010 | Canon IXUS 80 IS Digital Camera
Canon sd1000 time and date dispay on images
The SD1000 has a built-in date stamp function but it is only available in the postcard (1600x1050) function mode. Once you switch to this mode, you can then enable the datestamp feature in the main menu.
If this is unacceptable, you can use some image editing software to add the datestamp after the photo is transferred to your computer. The date/time information is actually stored in the image's EXIF information.
Dec 20, 2009 | Canon PowerShot SD1000 Digital Camera
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Jul 20, 2009 | Canon PowerShot SD870 IS Digital Camera
Date and time in prints
This function only works in "postcard" resolution. Press function button, and select postcard (1600 pixel width) resolution.
Jun 14, 2009 | Canon Cameras
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Turning off recordng message.
You can turn the display off during playback mode, however, if the display was on during recording, that cannot be turned off. . 1. Press the DISPLAY button on the left side panel. 2. Each press of the button toggles the OSD function on and off. When you turn the OSD off : * In CAM mode: The STBY, REC, EASY.Q modes are always displayed on the OSD, even when the OSD is turned OFF and the key input is displayed for 3 seconds then turned off. * In PLAYER mode: When you press any Function button, the function is displayed on the OSD for 3 seconds before it turns off. Turning the DATE/TIME on/off * The DATE/TIME is not affected when the OSD function is switched ON or OFF. * To turn the DATE/TIME on or off, access the menu and change the DATE/TIME mode.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Vivitar Vivicam 5105s Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
