Question about Logitech Webcam
Device not recognised - Logitech Webcam
Cannot find FM Radio on Card
FM radio is ascertained with popular adveretsiments. For example, once ascertain that 106.10 transmits popular enterment media requires to restore to memory. Recent devices recognise the user requests by allowing to search at button feature functions until available signal broadcast were discoved also memorised on device. In situation that the device radio least has auto scan to capture require to manually tune until an available signal broadcast were recognised. Also with devices least with momory features requires to humanly keep to memory the radio frequency. For example 106.10 is recogniseable as party station.
Examples of radio stations
98.1 FM
99.3 FM
94.9 FM
102.3FM
Mar 02, 2011 | Computers & Internet
ST300003U2 hard drive powers up ok, power light on, message on pc "usb device not recognised " .one of the usb devices has malfunctioned and windows does not recognise it.
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
Dec 22, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Jul 19, 2009 | LG GSA-E40L Burner
Cannot recognise the device
MP3 and Digital Media Players Cannot recognise the device I got this W660i after fully charged and plug to another computer it said cannot recognise the device, I have Window XP.
Jun 02, 2009 | Audio Players & Recorders
Device not being recognised - USB device not recognised...
Are you running windows media player on Vista, if so I'm having same problem. Appears one needs Windows XP, which is rather annoying..
Jan 31, 2008 | Samsung YH-925 MP3 Player
TomTom Home does not recognise device
Have you created a TomTom account? For each device you own it needs its own e mail address which it links to and you need to be logged in when you plug in your Tomtom.
Oct 22, 2007 | Tomtom ONE GPS Receiver
Logitech Webcam Logo
13 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
