How do i connect headphones to my system , my tv does not have a headphone socket so i need to try and get it through the surround sound , regards jim
  • 58 Answers
Connect you system through analog outputs of your tv if your tv supports such connections.
Posted on Apr 05, 2011
How do I connect my LG 32LD350 to a samsung HW-E350 sound bar? My tv does not have audio out jacks.
Sorry but you cannot do this with this tv.. You need hdmi 1.4 support and you only have 1.3 the only way i have heard of it being done is through the headphone socket to a 3.5 jack to the aux socket on the soundbar.... johnB
Feb 22, 2013 | Samsung HW-E350 Crystal Surround Air Track...
Turning off
I got a DAV system that had exactly the same problem, ie. it was stuck in "headphone mode", this mode should be active when headphones are attached then it should revert to amplifier mode when the headphones are removed.
I opened the cover and removed the amplifier output board (the one where the speaker wires connect to) and soldered the following dry joints.
1) large brown capacitor on the amp output board.
2) dry joints on the rear headphone socket (the one that has the connecting lead from the front headphone socket)
3) Then one of the surround channels didn't work so I soldered further dry joints on all the coils (white vertical rectangular blocks)
I tested all surround chanels before putting the lid back on (careful, watch the mains) and found all was now working ok.
Mar 11, 2008 | Sony DAV-S500 System
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
I bought an asda surround system model SP550. Four speakers connected to main console. But should there be anything that connects to the TV?
This is more of a multi media speaker system for your PC, so you will notice the cable provided my not connect to your TVar all. You have to connect the mini 3.5mm headphone pin into the headphone socket of the TV. If you do that only the front two speakers and the subwoofer will work ( 2.1 mode ). The surround speaker will stay silent because you cannot use the second pin on your TV.
Mar 09, 2011 | Audio Players & Recorders
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
I connected my DELL MINI Inspirion 10 via HDMI to LCD TV. have a good pic, but haven any sound (can play movie, but nothing voice). Check everything, no find problem. Can u help me?
Hi
HDMI is only used for Video output and not for sound, you will have to use your laptop audio out (has a pic of headphones), you are able to get headphone jack to phono (white / Red) cable to connect to TV or surround sound system or your laptop speakers.
Regards
David
Dec 30, 2009 | Dell Inspiron Mini 10 Notebook
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I have surround sound stereo and i am tryng to hook it up to a sylvania 6620LF4 t.v., i tried plugging the audio cables into the headphone jack and it didn't work, so i tried headphones to make sure that...
You'll need an Audio Out connection on the tv for surround to work properly. The signal level and the impedence mismatch of a headphones jack would not work or work poorly.
Aug 22, 2008 | Televison & Video
 Grubhead
Grubhead
