Question about EA - Electronic Arts The Poppit Show for Windows
Poppit show will not install on windows 7 64 bit
  • 58 Answers
It is not compatible with win 7/64 bits
Posted on Apr 05, 2011
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Tip
Install Unsigned Drivers on Windows 7 & Vista with Driver Signature Enforcement...
Every time when we try to install any hardware drivers which are not signed by microsoft, Windows shows a warning of Unsigned driver dialog box. The reason of showing warning message is to protect the stability of your Windows operating system as such drivers are not passed in Microsoft windows driver compatibility test.
In Window XP you can still install unsigned drivers but in Windows Vista SP 1 and Windows 7 Microsoft has introduced very restricted module of driver signature enforcement which doesn’t allow us to install any incompatible unsigned drivers.
If you want to bypass or disable Unsigned Driver warning message then Here is small freeware utility Driver Signature Enforcement Overrider which allows you to install and load unsigned drivers dynamically on your Windows 7 and Vista.
Supported Operating System
1. Windows Vista 32-bit & 64 bit
2. Windows 7 32-bit & 64-bit
Download Drive Signature Enforcement Overrider 1.3b
Please Note: User Account Control (UAC) must be disabled in-order to use this tool.
on Jan 10, 2010 | Computers & Internet
Why cant i install windows updates-it shows error0x80040609
Uninstall windows Live Essentials
Below are the steps on how to uninstall Windows Live Essentials via CMD line parameter.
a. Go to Start ->All Programs ->Accessories
b. Right click onCommand Promptand select Run as Administrator
c. Run the following commands to uninstall Windows Live Essentials:
· (64 bit) "c:\program files (x86)\windows live\installer\wlarp.exe" /cleanup:all /q
· (32 bit) "c:\program files\windows live\installer\wlarp.exe" /cleanup:all /q
d. A dialog box shows status until uninstallation has completed
The uninstaller for Windows Live Essentials 2011 can also be downloaded
May 13, 2014 | Microsoft Windows 7 Ultimate for PC
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Sims 3 site
The site was probaly down. Has it ever worked for you? Do any other websites work for you. Make sure internet is turned on.
Feb 13, 2013 | EA - Electronic Arts The Poppit Show for...
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
I have American Heritage Dictionary cd rom but when I tried to install it into my new laptop which runs Windows 7 64-bit, it showed that the program cannot be installed in 64-bit system. How can I install...
It is not possible to install 64 bit application in to 32 bit machine, as it has been designed for the 64 bit operating system which has n different architecture.
better check with the product site for 32 bit compact ability.
Oct 15, 2010 | Computers & Internet
Installed 4 G of RAM. Installed Windows 7. Only 3 G RAM Usable
To recognize more than 3GB of RAM you will need a 64 bit version of the operating system. If you install Windows 7 32 bit (normal for most users) you will only see 3.
You should have both versions of Windows 7 (32bit and 64 bit) on your installation disk. However you will need a 64 bit capable processor to install it. Otherwise 3GB of RAM for a 32 bit operating system is more than enough.
Mar 08, 2010 | MSI PT880 Neo FSR Motherboard
No o-rings on the poppit spider 4.3 1994 S10 (acceleration miss)
OK I'm going to try this: There should be a rubber "o" ring around each injector (seems like a loose fit because the rubber has some "give") If you've had it apart and there were no rings either on the injectors or still in the head, there should be.
System vacuum does not open the injector, it is activated by an electric solenoid inside it. (why there are wires going to it)
I don't know what problem you have but regarding injectors, sometimes besides electrical failures and fouling, the orfice gets worn (as does any high pressure orfice ie: the nozzle in an oil fired furnace) This affects the spray pattern and amount of fuel being emitted.
And as far as american cars go, chevy isn't too bad...I once owned a Rover 2000tc It drove me crazy!!!
Mar 23, 2009 | 1994 Chevrolet S-10 Blazer
EA - Electronic Arts The Poppit Show for Windows Logo
136 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
