Question about Agfa SnapScan 1236u Flatbed Scanner
Drivers for w7 - Agfa SnapScan 1236u Flatbed Scanner
X64 w7 driver
Why don't you look at the Canon website for the drivers you need. It isn't the most obvious place to look I know, but worth a try (don't you think?)
Oct 10, 2013 | Canon imageRUNNER C3200 Copier
Burn windows 7 iso for hp laptop to dvd
OLD DV6910. note book. (circa 2007 ) near end of HP support.!
MS stopped VISTA this spring.
no, toshiba is no good, as are all other PCs makers disks no good. your PC us USA HP computer, its not from Japan.
sorry. only MS disks or best of best HP disks work.
the ISO from MS, how'd you get that, and when.?
the current link at MS needs valid RETAIL COA code to download it.(oem codes not)
The MS disk do not have all drivers need, to make an HP pc run..
sure it will load, but many things CAN be dead.
is your F11 restore dead too? (its VISTA, if you dont know)
power on , F11, f11, f11, f11 , hammer it. see the HP restore?
here is your official HP support page.'
https://support.hp.com/us-en/product/HP-Pavilion-dv6900-Entertainment-Notebook-PC-series/3725196/model/3740554
see? that
and all were shipped with VISTA, and F11 key restores
VISTA , there is no W7 drivers. from HP , zero
"i got image to burn.?"
so then what?, did you install W7?
and see all those dead chips? in device manager
did you get Ethernet working first so W7 can PNP the drivers automatically, /??
Things that can fail are.
HP special drivers for like , hot keys, that MS does not have
all HP apps will be missing.
and all drivers for old vista chips not supported under w7
see?>
MS loads. here is the path (using ms, disk and not HP media kit)
why not get the HP kit from HP???????
  1. Get MS w7 ISO, from MS using the $120 key, COA key,
  2. oops the HP key is no good, its OEM key/.
  3. down load ISO from MS.
  4. burn a USB stick or DVD from ISO, (Rufus, or imgburn free)
  5. boot PC using BIOS boot to DVD or stick as the case applies.
  6. W7 Loads, ok. (it runs sure, but...)
  7. W7 fails on Ethernet or wifi, one must work now or doomed, lacking other PC to find drivers from chip makers or MS.
  8. I wire up the Ethernet jack RJ45 cat 5 to my router.
  9. the internet is connected, i then let W7 find the drivers, good luck finding them all.. some can be missing, on 10 year old LT.
  10. if at wits end see this , on how to get them the HARD way.
  11. http://www.pcdied.com/Drivers.html
if you make a PCI scanner boot disk (or stick)
http://www.pcdied.com/pci-101.html
you can find most drivers. (mine never fails)
using he scanner on any PC we see all chips
and with vista drivers failing on w7
we go to the makers site and get the W7 driver
as seen here, PCI sniffer3 , I uses this all the time.
for exactly this reason.
the HP media kit DVD set is for VISTA only.
sorry.
Aug 12, 2017 | HP Pavilion Computers & Internet
I've got a HP Pavilion DV 9700 with 3GB RAM, it's running Windows 7 professional 32bit. It has a video card Geforce 8600m GS, I downloaded the drivers from the Nvidia web page but the driver doesn't seem...
ITS a NOTBOOK, with fixed GPU. (cant change that)
so what was this PC new. what OS? VISTA
and you put on w7?
if yes, did you look up the rules for w7 on that. first.
that is step one, btw.
i think your OS was changed from VIsta to w7
try the Vista driver below. it might work,.
so why not use the HP drivers,for your PC and leave nvida out.
if the HP drivers fails, due to wrong OS, the ask Nvida for help.
not HP. see? If HP does not support w7 , asking them is fail.
first get right 32bit and 64bit, do that first. then pick W7
then pick GPU driver.
ask HP no matter.
they had Nvida chip or Intel, using the wrong chip driver is FAIL
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9700-entertainment-notebook-pc-series/3632106
Jul 05, 2017 | HP Computers & Internet
Sony eye motion not found after W7 upgrade VGN-CR11S
you would need w7 camera driver.Being an older model i doubt you will find them .
Feb 19, 2010 | Sony VAIO VGN-FE880E/H Notebook
Upgraded to windows 7 cant find software for web cam i dont have cd,where can i find this software for advent 6651
W7 comes with thousands of drivers pre-installed. If it is compatable with W7 it will automatically install the required driver. Have you plugged it in and allowed W7 to try to install it for you? There are other solutions also if this doesn't work.
Dec 06, 2009 | Recoton Advent Advent Q2035A 20" TV
Just installed new dell 23 inch widescreen monitor with cam and it turns off ('no connection to computer" message) just before xp sp3 desktop load, works fine with windows 7.
drivers for xp sp3 may not be compatible with w7 drivers.
running dual partitions? xp/w7? could be drivers are not getting along! sounds like microsoft to me!!
good luck
Oct 18, 2009 | Computers & Internet
I installed windows 7 os and my mother board drivers not support that os.help me.my mother board is asus p5rd1-vm. pentium 4 processor 512 ram
Come back on XP or Vista but XP works better.There is no driver for W7 yet.Motherboards manufacturers will provide drivers for W7 when Microsoft will announce that the system(W7) is ready to be sell....Windows 7 is still beta! If Microsoft still provide "UP DATE" for XP why you want to install other OS?
Mar 10, 2009 | ASUS P5RD1-VM Motherboard
Agfa SnapScan 1236u Flatbed Scanner Logo
162 people viewed this question
Top Agfa Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
