Question about Vacuums
My dirt devil DHC001 hand held vacuum just stopped working whilst it was switched on. It is quite hot and I have checked that it is not the socket.
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: dirt devil model 0914 cordless 15.6 volt
Go to: http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=b7c83c5d-3797-452a-bd73-4e0ed0ecc993
You can download a user manual from this link.
Posted on Jan 15, 2008
SOURCE: dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
Posted on May 14, 2009
  • 52 Answers
SOURCE: i need the manual for a dirt devil hand held wet
Follow the link below to download your manual. It's free!
http://www.dirtdevil.com/manuals/?id=8d4f4999-67e5-47f1-a43a-7714b3d2c430
Posted on May 19, 2010
  • 4102 Answers
SOURCE: our dirt devil bagless upright
Hi, no im afraid its not that easy, the problem is with the wire that goes into the vac from the mains, now you see where the mains lead goes through in the back of the vac well what happens is when you vacing and moving the vac around this part wears and causes a short or loss of connection, now it usually happens when your using it then the free cable runs out and it pulls on the vac when you try goign further than the wire reaches, so the problem you are having is with the connection between the wire and the on/off switch, this is a very common fault with all vacs of this type.
to fix it your going to need to remove the cylinder and see if their is an access panel on the front of the vac behind the cylinder you take off to empty.
how ever if you have no electrical skills then its not safe for me to tell you how to do this repair, if you get it wrong you could do harm to anyone who uses the vac ok so be warned i have told you this ok.
the work involves removing the panel the other side of the switch then you need to undo the wires going to the switch you then need to pull the mains wire out of the vac so its no longer connected then cut it back 3 or 4 inches so as the part that is faulty has gone then you need to fit it all back together the right way round and make sure their is no bare wire showing and that it is all secure and then it should work.
but before you do all that check the fuse in the plug first as if its got hot this fuse may have blown so i would check that first before you decide what to do next ok.
it wont cost much to pay someone to do this as it wont require any parts, if you could take it to a reapir shop yourself then that will be even cheaper as you wont be paying a call out fee, also check if you have any warranty left on it as this fault wil be covered
let me know how you get on or if you need further assistance ok
please can you rate this solution as i have a whole page of unrated posts, thanks
Posted on Feb 19, 2011
Ii have a hand held dirt devil and it as a little black switch on the side which says open on one side and close on the other...what is his for
Perhaps you could move the switch to OPEN to find out. Most likely it gives access to the dirt bag/container.
Mar 03, 2017 | Dirt Devil Vacuums
Dirt devil sd12000 hand held vacuum less than a year old wont turn on
take it in for a warranty check if the period is a year warranty
Oct 02, 2016 | Dirt Devil Vacuums
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
Dirt devil turbo clean sd40060 Cyclonic vacuum. Was given it as a present. Floor tool won't spin. Checked everything! Belt, for hair through out. All ok. Why isn't it working?
You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Aug 08, 2015 | Dirt Devil Vacuums
How a can find the manual from m100 vacumcleaner.Thank
Hi, it's Jeremy from Crucial Vacuum.
Below you can find a link to a users manual for the Dirt Devil M100 Hand Held Vacuum:
http://dirtdevil.com/file/7/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 27, 2014 | Dirt Devil M100 Hand Held Vacuum
Belt change on hand held dirt devil
No, just the chrome plate that covers the brushes
Jun 27, 2010 | Dirt Devil Classic M08100 Bagged Handheld...
Where does hot water go, and cleaner go?
Check your model number.
From the Dirt Devil Website http://www.dirtdevil.com/products/details.aspx?id=MCE7000 on the right hand side is a User Manual link.
You can also find other user manuals for other models.
May 25, 2010 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
