Question about Hoover Washing Machines
Hoover Easy logic time saving system.  Auto
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 1314 Answers
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
SOURCE: washing machine will not empty or spin out
washing machine will not get empty or spin out
Posted on Sep 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: hoover easy logic error message number 3 model is a EL 160
E3 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain program.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Hp pavilion a4311f, hp support assistant still frozen and 'a error occured'
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Apr 17, 2012 | HP Computers & Internet
Nextra6.will only go on 40min wash and only spin on slow spin. checked motor brushes and there fine. is it the circuit board
I have a hoover optima 1400AAA, it began to give trouble with programs, 40 degrees washed at 80 degrees, would not spin or empty, etc, called in a hoover repair man who cost me 120euros to remove the program knob and spray the contacts with Servisol super 10 switch cleaning lubricant, apart from the fact that I am still furious, everyone who has a hoover washing machine should know this.
Mar 21, 2012 | Hoover Nextra HNL 3166 Z Front Load Washer
I need a replacement door for my Hoover Easy Logic 1100 aa Washing machine. I beleive that the model is discontinued but my machine is in perfectly good working order. Could you advise anywhere where I...
I searched for quite some time without success and I am Pretty good at finding things.
Contact Hoover using this link:
http://service.hoover.co.uk/spares
To order Hoover Genuine Spares & Accessories please call 08443 712758
Opening hours: Mon-Fri 8.30am - 5pm.
I could not even come up with the part number for the door. I did find the following:
1. Door Seal
2. Door Glass
3. Door Handle
4. Door Hinges
No luck on finding the complete door assembly.
Another alternative... if the Yorkshire area has an appliance recycling venter you may be able to find one there or in the classified ads "for parts only" But then your faced with disposing of the "junk."
I recommend you contact Hoover using the number or Lonk above and see what they can do for you.
I wish I could have done more for you but the whole door assembly just does not seem to be readily available.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Washing Machines
The door on my hoover easy logic 1100aa washing machine will not open. The wash is complete and there is power???
is this one of the newer HE machines?
the washer may not recognize that the cycle is complete even though you think and see that it has -- can you try running another cycle?
Best regards
Ck
Jan 05, 2011 | Hoover Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
78 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
