Question about Dryers
Hi, I have a Tempo clothes dryer and it seems to be sweating and moisture dripping out of it. Is this a problem? Regards, Alan Beatty
  • 59 Answers
CHECK THE EXHAUST TUBE FOR BLOCKAGE.
Posted on Apr 06, 2011
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
My Miele T294C NOVOTRONIC TUMBLE DRYER KEEPS STOPPING AFTER A FEW MINUTES OF DRYING. I CAN SWITCH IT BACK ON IMMEDIATLY ONLY FOR IT TO STOP AGAIN. CAN YOU HELP?
Hi - it seems likely the moisture sensor unit is faulty, reason?
Well Miele dryers after you start up will actually try to work out the amount of moisture in the dryer, it will calcualte the time & temp required to correctly dry the load in the machine. I suspect the sensor is not functioning proper.
I will assume there are no messages or other indications or flashing lights on the right side of the knob - it would be nice to plug my laptop to it and find out for sure..
You have cleaned the heat exchanger unit in the bottom corner of the dryer, the filter in the door and the two on the bottom of the door opening..
Despite all of these I would lean on the faulty sensor as the most likely culprit.
You may have to locate the nearest Miele service agent to help you out...
cheers
Jun 22, 2011 | Miele Dryers
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
Dryer won't shut off automatically
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
Why is the dryer not turning off
Hi, If your dryer seems to run forever and doesnt turn off, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Apr 15, 2010 | Roper REX4634KQ Electric Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Dryer does not stop. time shows flashing rectangle.Is this normal
Hi There
I have this for you to read this should get you on the right track. Let me know how it went.
Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Samsung WF203ANW Front Load Washer
Moisture in my dryer
moisture in tha dryer is definatly an issue with not being able to vent out the moist ais from drying the clothes, did you check where the vent exits the home?, the only way moisture collects in a dryer is by not properly venting it out...
Nov 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
174 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
