Question about HP iPAQ hw6910 Smartphone
My HP iPAQ HW6910 keeps freezing. Sometimes it loads up to the main screen and then freezes after about 30 seconds, other times it gets as far as the windows loading screen and then most of the time it doesn't get past the first welcome screen that displays the HP logo and title HP iPAQ Mobile Messenger. It also has a code in the bottom right hand corner of the screen (the logo screen) which reads 1.00.00 and then underneath that 1.21UK. Is this a software problem or a hardware problem?
  • HP Master
  • 2,305 Answers
HP iPAQ week, wow.
let me guess , hp has no support now in this old thing and you need help.question 1: why use this thing,question 2, how much will you spend on this worthless broken thing? or buy parts, or batteries for it or 3 how much labor on such and old thing is warranted.?
Posted on May 30, 2017
  • 16 Answers
SOURCE: black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Posted on Apr 17, 2008
SOURCE: Ipaq hx2190
hard reset for hx2190
Posted on Aug 23, 2008
  • 31 Answers
SOURCE: HP Ipaq 2910 wont finish the boot
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Posted on Oct 13, 2008
SOURCE: Won't get through blue HP startup screen.
try taking battery out for 6hours then reinstall and hard rest.
this works on mine. bob
Posted on Aug 26, 2009
SOURCE: Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
My ipaq 214 wont boot up. it just freezes on the HP screen. Ive tried pressing the reset button like over 100 times but it just freezes again. Ive also tried hard reset and that dosent work either. I have...
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
Have a great day!
Oct 11, 2009 | HP iPAQ 214 Pocket PC
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Sep 01, 2008 | HP iPAQ H2210 Pocket PC
HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
If still freeze after the resets, then try to do a Hard Reset.
With this way you will restore your device at the default condition.
Take care to remove any external memory from iPAQ before to this and also have it
full charged.
The bad of this....you will loose everything stored at the internal memory of iPAQ.
The good this...your iPAQ would be alive again ;-)
To to a Hard Reset press at the same time the reset button+calendar button+today button.
Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
Doesn't move past the initial screen even on reset
If soft AND hard resets do not work, you definitely have a major problem. Sometimes, there will be problems that cause frequent freezes in the boot process. These freezes, in my experience, though, have been random, and in different places in the boot process. Try constant hard resets (patience is key, as sometimes they take a long time to load) until you get to the main screen. If you cannot get there, I really don;t know what to tell you. If you do, even once, refer to
http://www.fixya.com/support/t395941-display_operating_difficulties
for a permanent solution to your problem. (I know you two have different problems, but the solution should be one and the same)
Happy fixing!
Jul 17, 2007 | HP iPAQ RX3715 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
IPAQ freezing after hard reset on the 9am dental appointment screen
https://h30434.www3.hp.com/
ask hp so all can laugh.
this thing is 100% obsolete. now.
try new battery yet?
Aug 12, 2017 | HP iPAQ RZ1710 Pocket PC
HP iPAQ hw6910 Smartphone Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
