Question about Carrier 52PQ307 Wall/Window Air Conditioner
The over load device burned up,," fryed" I"m
  • 1 more comment
  • Roger Jelinek Apr 05, 2011
    You mention the compressor over heating. Compressors are protected internally by a thermal overload embedded in the motor winding. Some units do have a second overload for low voltage, but that's not normal for smaller compressors. If the capacitor is a metal can and has swollen up, replacing it may solve the problem. All of this is on the line voltage side of the system though and should not have burned up a low voltage over load. Before trying to start the compressor, disconnect its wiring and test each of its connections to ground. A burned up over load on the low voltage side is a different problem and tests. Let me know how you are doing. I will explain further tests if you need me to. Please rate this response. Roger
  • bruced94 Apr 07, 2011
    Hi Roger
    On the top of the compressor their are 3 wires under a cap. One to run one to start ,one to common.The wire to common has a device the schematic calls a overload it sits under the cap that covers the wires on to of the compressor. The cap holds this device to the top of the compressor.. this device is fried.
    The symbol on the schematic looks like 2 fish hooks stuck together at the hook ends. It says Klixon on top of the device.. It looks like it was to open the circuit when the compressor got to hot. This is a Carrier model #52CQ501204.... AC-- Heat Pump. This device is about the size of a twist off cap from a soda bottle with wire terminal plug slots on top.. Coffee pots use something like this to regulate the pot warming plate temp. It reminds me of them.
    HI ROGER
    Klixon overload # MRA4726 was my trouble .... Where can I buy this part? I cant find a place to buy AC- heat pump parts I live in New jersey.. WEST MILFORD NEW JERSEY 07480
    you have given enough info to figure this out,, if you could lead me to parts you would make me a happy camper .. Im retired and trying to save a buck. Thanks for your help.
    Bruce
icemelts
  • 246 Answers
SOURCE: I have purchased a new capacitor to replace the
those little clips are hard to find (sort of) but I would think Home Depot, Lowes, or any hardware store would stock them.
if not - you can always go to an 'air conditioning supply house' (wholeseller) - or an 'electrical supply house.' (fyi most wholesellers will sell to anyone, but not at a wholesale price necessarily).
good luck!
Posted on Jun 22, 2010
  • 143 Answers
SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Posted on Jul 22, 2008
relaga58
  • 158 Answers
SOURCE: condensor fan not running after replacement
check fan rotation
Posted on May 31, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Have carrier heat pump that buzzes
What exactly does it do? If it buzz and don't turn a starting capacitor will not help, this is an indiction of a shorted motor.
Posted on Jul 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Weatherking 3 ton Run Capacitor
Could be; age,lightning,power surge,defective wire,loose wire,tight compressor. Capacitors fail sooner or later. They are like batteries they do not last for ever.
Posted on Aug 04, 2009
Imperial 40 ignites but does not extend flames into heating tubes. Burns only fron
It sounds like your gas line either is clogged or your heating tubes are clogged up with oil/dirt/gunk? You can blow these out with a small hand held compressor or if you have a small enough brush, you can use that to clean it. The compressor is the quickest way, but have you cleaned this unit at all? Using a fryer boil out and running the fryer will also help clean out your holes, but again, the compressor works best.
Nov 21, 2011 | Imperial IFS40 Deep Fryer
Our model is a ED2PHEXMT .. bought 6/2003 Woke up in the nite to terrible plastic burning odor from the frig. Took it out of the house and removed the rear cover this AM ... the "relay"(?)...
Good day,
Sounds as if the relay burned up, or the compressor shorted out. Yu can remove the relay by unclipping the cover and pulling it off the compressor pins. The part should be available at any appliance parts house selling Whirlpool parts.
However, it could as well be a shorted compressor that burned the relay out. I would suggest you call a professional to service it. They have the equipment to test the compressor.
If the machine is under 5 years of age, leave it alone. The compressor is still under factory warranty.
Call your selling dealer for details on a warranty service call.
Nov 12, 2010 | Whirlpool ED2FHEXM Side by Side...
Heating element burned out (literally!)
No you are fine...just replace the element, they will fry like that sometimes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
After i put the ac on my bmw x5 2003 get over heat and smell burn
pls. check your ac compressor magnetic clutch attached in front of ur compressor if its working/ ac clutch engage when u turn the ac switch on and disengage when u turn the ac switch off/ it normally makes a clacking sound when it engage with the rotation of ur compressor/ if its not engaging it means ur magnetic clutch is stuck up giving excessive load to ur engine thats why it overheats/ it smell burnt because its magnetic coil is fried/ or check cooling system of ur car might be that coolant is empty/ fan is not working/ radiator is clogged or thermostatic valve is stuck blocking coolant flow....
Apr 09, 2010 | 2003 BMW 5 Series
Front Load Maytag Neptune won't spin.
check the board
is the resister thats burning r-11
if it is you need to change the wax motor lock as well
its the door lock found where the door latch goes in
ive included the part number 22002119
they should have told you
Oct 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
LCD projector spots showing up on the screen
there are light filters behind each lcd panel that determine the color of light going through it. because of excessive heat and dust, the filter tends to burn and cause discoloration in the image. if the image is bluish (cyan), the red filter is burning. if it's yellow, the blue is burning. if it's purplish (magenta), the green is burning. the filters will need to be replaced. unfortunately, many companies don't sell individual parts of the optical engine, so the entire engine might need to be replaced.
Aug 20, 2009 | Epson EMP S1 Multimedia Projector
NO HEAT, RUNS LOAD, SMEELS LIKE SOMETHING IS BURNING
The thermostat could be fried. As in really fried.
Jan 16, 2009 | Amana NDE2330AY Electric Dryer
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
Carrier 52PQ307 Wall/Window Air Conditioner Logo
73 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
