Question about JVC Everio GZ-MG21 Camcorder
I have the software disc but it's not available for windows 7 version, what can I do
  • 58 Answers
Try checking on the following link for a video converter tool;
http://www.daniusoft.com/mod-converter.html#123
Posted on Apr 05, 2011
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
When i want to download drivers but my computer
Emm,
Are you currently using a licensed version of Windows on your computer? This occurs when you are using a trial version and not a licensed version of the operating system. If you installed the OS with Manufacturers discs you should have a license key available and follow the steps here (if you are using Windows 7): http://windows.microsoft.com/en-us/windows7/activate-windows-7-on-this-computer
If you do not have the license key for the OS, you will need to obtain a licensed version and either install the OS or use the key if it is the same OS you are currently using.
Hope this helps,
Scott
Oct 01, 2013 | Computers & Internet
We have Performance Now Version 4.0.0.10 and it will not run on Windows 7. Is it suppose to run on Windows 7? If not, what version does run on Windows 7?
It may not run on Windows 7. Windows 7 by default tells you if there is known compatibility isuues with the software. I suggest looking up their website. It probably has info on the latest release of the software.
Mar 22, 2011 | Knowledge Point Performance Now! 4.0 for...
We have an old version of Green Globs and Graphing Equations that does not work with Windows 7. Is there an update or patch available? Thank You.
According to a statement made by David Kibbey, President of Dugdale and Kibbey Consulting, Inc. (copyright owner of Green Globs & Graphing Equations):
"Sunburst's license to sell or distribute Green Globs & Graphing Equations expired July 13, 2010. The only version available now is our 2008 version at www.greenglobs.net, which runs on Mac OS X and Windows PC's (including Windows XP (and some earlier Windows versions), Windows Vista, and Windows 7)."
This appears to be the only (and probably last) "current" version of the software.
Mar 01, 2011 | Sunburst Green Globs and Graphing...
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Why can't I download my CANO SCAN set up CD-Rom on to my new Windows 7
The CD-ROM has the installers for older versions of Windows. The installation routines for the newer versions of Windows have changed considerably from those that were in use when the CD was written. You can get the drivers and Canon Toolbox software for the scanner from Canon: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware . Select Windows 7 in the dropdown menu. The software will work with any version of Windows 7.
The only exception is that the third-party software is not available for downloads. If you want to use the original CD software (assuming the disc is undamaged) and you have Windows 7 Pro or Ultimate, you can download and install Virtual PC and XP mode for a free XP virtual computer. Then install the scanner to the "XP computer" as you normally would. However, the virtual computer and the Win7 computer cannot both have the hardware installed simultaneously. So to share files, you may need to save them to external media (optical or hard drive). If you have one of the other versions of Windows 7, you can do the same thing with any virtual PC program and a licensed older version of Windows.
I hope this helps.
Feb 12, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I have Window Explorer Installation CD, but looks like I am not able to load to my computer with Which has a Window 7 software on it, how can I do?
You can download the drivers from Brother. http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7340_us_as and select your version of Win7. The full software is available and there is a patch for the Control Center 3 as well. Download both.
I hope this helps.
(the old disc doesn't help because the installer code has been changed between Windows versions.)
Jul 26, 2010 | Brother MFC-7340 All-In-One Laser Printer
Webroot 6.1 Antivirus/SpySweeper won't open after install
Dear User,
Though Webroot 6.1 Antivirus works fine on Windows 7, but its Spyweeper (anti spywear), is not seems to be compatible with Windows 7.
You can look for the version of webrrot that is fully compatible with windows 7.
OR
You can go to the free versions of Antivirus availables for Windows 7 (as AVG Free).
Thanks
Jan 24, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Scanner not working
There is not a driver available for Windows 7. One thing you can try is to run the software in windows XP compatibility mode if your version of Windows has it. When you go to run the software disc for the scanner goto my computer and right-click on the icon then click properties. You can then set the compatibility mode to run on XP. Then run the software by double left click on the icon after you have set the compatibilty mode for XP. I cannot guarantee this will work but it is worth a try. If you download the software to the desktop the process is the same.
Dec 24, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
JVC Everio GZ-MG21 Camcorder Logo
32 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
