Question about Kyocera FS-3900DN Laser Printer
Problem with the Kyocera FS-6950DN Laser Printer Call service 6000:0021041
  • 56 Answers
SOURCE: I have a kyocera A3
Hi, there is firmware problem,so you must upgrade firmware. It is best solution to call service.
Regards
Posted on Apr 26, 2008
  • 40 Answers
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
Posted on Jan 10, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
  • 62 Answers
SOURCE: call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Posted on Jan 16, 2010
Testimonial: "This worked, thanks!!!"
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
Jun 27, 2014 | Kyocera Mita FS-3820N Laser Printer
Printer is not recognised by computer when usb connected. using XP PROF
Hi
Change your USB cable and try again.....you fix your problem.
Jun 01, 2011 | Kyocera FS-6950DN Laser Printer
Paper jam in fuser unit
It sounds like the EJECT switch in the fuser has been knocked out of position
May 18, 2010 | Kyocera FS-6950DN Laser Printer
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Jan 20, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera fs-2000d printer
A KYOCERA-MITA technician has to upgrade the firmware.
Jan 31, 2009 | Kyocera FS-2000D Laser Printer
KYOCERA FS-1900 ERROR MESSAGE CALL SERVICE 2000:0137037
the 2000 part relates to a laser unit problem the other numbers are the print count.
You will need to have this serviced by a tech and if you are a tech you will need to order a new laser unit
Dec 21, 2008 | Kyocera Mita FS-3830N Laser Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
I have a kyocera A3 duplex laser, that displays "Call Service 0150:0000000" It "happened" mid stream, while printing. It is an FS-6950DN
Regards
Apr 26, 2008 | Office Equipment & Supplies
Service code
This is a laser problem. The polygon motor probably got jammed usually it needs to be cleaned and oiled or the motor has ceased.
Mar 10, 2008 | Kyocera FS-3900DN Laser Printer
Call Service issue
Hi sunny82 ,
I think You have defective laser unit,but first try to clean it.
Sep 23, 2007 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-3900DN Laser Printer Logo
143 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
