Question about Bosch Drills
How do I remove chuck from bosch psr 1440 drill
  • 710 Answers
Hi Tracy,
From the parts diagram that I looked at, it looks like you can open the chuck completely and remove it with a screwdriver. There is a screw in the bottom of the chuck. However, if your drill doesn't have a spindle lock, I'm not sure it can be done, except by a repair shop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 05, 2011
Bosch PSR 1440 power drill. How do I know when the battery is charged?
Tracey,
There should be a legend on the top of front of your charger that should explain the light sequence for the charging process.
May 15, 2015 | Bosch Drills
How do i change the chuck of a bosch psr 10,2 li cordless drill
Hi. When the 3 pins are opened all the way there is a phoenix type screw in the centre of the chick.(inside where the drillbit comes) There you can hold the chuck with hand or bench vise and unscrew the bolt holding it secure. spray some wd 40 on the base and gently wiggle it out.
Feb 26, 2015 | Bosch Drills
Remove 1014vsr bosch chuck
The greatest one that fit most chucks are 13mm but remember to remove the torxscrew (in clockwise direction) inside the chuck first and if you use a new chuck beware of to use some loctite on the screw.
The long side in a vice the short in the chuck and turn the left anticlockwise direction the L direction and pull short but fast the trigger and move the drill in the same direction turning the drill has priority to make doing this in a very short time. to not overcharge you tool.
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
Oct 12, 2013 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Bosch 12V cordless drill PSR 1 ?ES-2 One of the three jaws unscrewed a little and protruded beyond the other jaws by approximately 4 mm but has now completly unscrewed and fallen out. I can not unscrew...
It is left hand thread and yes sometimes you have to use a little force to loosen it. I don't know if you will be able to reinstall the jaw from the chuck, I havea detailed instructions on chuck removal in my tip section.
Aug 30, 2011 | Bosch Tools & Hardware - Others
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 15, 2011 | Bosch Drills
HOW DO I PUT THE QUICK RELEASE CHUCK ON A BOSCH HAMMER 11236VS?
I don't know that drill in detail but in general chucks for this type of machine are removed by pulling back the plastic ring behind the chuck and pulling the chuck out. So hold the drill with the chuck facing away fron you and grip the plastic ring behind the chuck (nearest you). Pull this toward you and pull the chuck away from you. Replacing a chuck is the reverse.
Jan 04, 2011 | Bosch Drills
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drills Logo
365 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
