Asd - Computers & Internet
    Scholar:
  • 83 Answers
What kind of problem? please specify the concern so we can help you
Posted on Apr 05, 2011
The 25 amp ASD fuse keeps blowing when i try to start myTown & ountry 2001
In that case you have a dead short somewhere. This suggests replacing the ASD relay, and there is a neat trick using a bulb instead of a fuse to track the problem.
https://www.2carpros.com/questions/2001-dodge-caravan-asd-fuse
And 'Chrysler Tech' here has good advice as to what is causing it.
http://www.chryslerforum.com/forum/chrysler-pacifica-15/asd-fuse-blowing-right-away-help-23819/
25 amp ASD fuse Google Search
Jan 25, 2017 | Cars & Trucks
Why asd fuse keeps blown
You have a Chrysler , dodge , or Plymouth ? ASD Fuse supplies power to ASD relay ,if you have a Dodge , Chrysler or Plymouth vehicle . You have a short to ground , videos on you tube , how to find a electrical short ! ASD - auto shut down , this powers Ignition system , fuel injectors , O2 sensors . A short in any one of these systems will blow the fuse . O2 sensor wires get melted on exhaust pipes an manifolds ! That is if you have one of these make vehicles !
Sep 28, 2016 | Cars & Trucks
Code P1388 and P1399
P1388 JEEP - ASD or CNG (compressed Gas) Relay Control Circuit Possible causes - Faulty ASD Relay (most common cause)
- Faulty CNG Relay
- ASD or CNG Relay harness is open or shorted
- ASD or CNG Relay circuit poor electrical connection
- ASD or CNG Relay poor ground or supply voltage condition
P1399 is a related to the P1388 failure.
Jun 27, 2016 | 2000 Jeep Grand Cherokee
Have a 2004 jeep Cherokee that has a p1389 code in
gee 1, last year of Cherokee is 2001, so you meant Grand right??????
gee2, wont start or stalls, no other symptoms????? just 1 DTC, no others using a real scan tool? that be first huh?
Geewise 3, what engine, wow, wrong car, no engine or country.?
the FSM covers this, and the ASD has 8 ways to trip off line'
UP TO 8 ways , just like old wonder bread had.
answering for 2004 GC, (i actually look it up in the real book)
not google butchered DTCs.
P means power train, 1 means factory codes.
a 3 coin toss lands...
2004 GC, vin N, 4.7L v8 automatic,
it reads. verbatim.
Trouble Code: P1389
No Auto Shutdown Relay Output Voltage To PCM
Number of Trips to Set Code: 1
  • Catastrophicmonitor failure.
Trouble Code Conditions:
Engine cranking; and the PCM did not detect any voltage on the ASD Relay Output circuit to the PCM during the CCM test.
Possible Causes:
  1. ASD relay connector is damaged, loose or shorted
  2. ASD relay output circuit is open between the relay and PCM
  3. ASD relay power circuit is open (test power from Fused B+)
  4. ASD relay is damaged or has failed
  5. PCM has failed (nah)
it means, to me.
  • the relay is unplugged
  • or fuse blown "fused B+" (a top reason, world wide)
  • the relay is bad.
my buds ASD page,
http://www.fixkick.com/Jeeps/ASD.html
Oct 20, 2014 | Jeep Cherokee Cars & Trucks
Asdad asd asd asd
Yeah, apple does that to people...
Jul 24, 2014 | Apple iPhone Smartphone
No power going to the fuel pump
first check all fuses.
well if the security lamp is on, and the IMMobilizer light glows
it will never run. (by design) (2 seconds max)
so are the lights glowing?
no power going. (when,)
did you read the FSM on the staged events to get engine started.
my wild guess? (sad i have to ask) is it wont start?
1: IMMO not active
2: battery charged volts near 12.6vdc rested.
3: starter cranks fast. and ASD closes
4: ASD relay sees good spark and CKP, and CMP sensors.
5: engine starts, if #4 is good then it sustains running.
if not ASD drops out in 2 seconds. killing INJECTION.
it cuts the fuel pump too.
the PCM will throw a DTC error code (did you scan it cranking ??)
for if the ASD fails to OUTPUT 12v. at step 3.
the PCM closes it, then looks, and if output is bad, it ends this event and logs the failure..
to check the pump , it takes 2 people
one at the key, and one at the pump wires.
or you WILL miss the 2second event.
one way to avoid all that is to hold finger on the ASD relay
and keyon and see if it clicks closed.
if not ., no need to check pump ,its LAST in the chain,
if the ASD clicks and drops out, during that click the pump does run
for 2 seconds, min.,
if the ASD is dead, check the PCM control line to the ASD for
making coil energized in the ASD relay, (12vdc across it for 2seconds)
if the coil is energized, and the DTC throws, for bad ASD , it is.
if the ASD goes, hot only for 2 seconds, again use any $9
scan tool to see the error.
here is the scan too tests. most books forget.
1: scan tool connected.
2; Crank engine for 5 seconds, (min)
3: release key. BINGO, the ECU tells you why the ASD dropped out.
eg: ASD error, CMP error, CKP errors or others (spark?)
does RPM read near 250rpm cranking? on the scan tool?
Is TPS throttle angle near 100% (cutting fuel) ? bad tps. (cut wires)
fixing cars without a $9 scan tool , as sold on feabay is 100x harder.
get the tool and use it.
they rent them cheap or loan them for free.
not to be confused with a code reader, which are near useless.
imo.....
Feb 11, 2014 | 2004 Jeep Grand Cherokee
Code p1388
possible reasons for the code:
- Faulty ASD Relay
- Faulty CNG Relay
Sep 17, 2012 | 2001 Dodge Grand Caravan
My ASD fuse is making a clicking noise and vibrating. What is the function of this fuse?
ASD fuse is called an AUTOMATIC SHUT DOWN FUSE. The ASD sense circuit informs the PCM when the ASD relay energizes. A 12 volt signal at this input indicated to the PCM that the ASD has been activated. This input is used only to sense that the ASD relay is energized.
When energized, the ASD relay supplies battery voltage to the fuel injectors, ignition coils, and the heating element in each oxygen sensor. If the PCM does not receive 12 volts from this input after grounding the ASD reley, it sets a Diagnostic Trouble Code (DTC).
May 18, 2011 | Jeep Cherokee Cars & Trucks
Asdfasd asd asd fsdf asd fasfd
Fghs asd asdft? Fgssa asda sdad dsada asdasdasda sadasda -> dasdasd dasdjkdasmnda adadka ad (asdsa). ADSA dsdsa dsadsaaasd S.D.A.F.G. sadas das dasda. Assddses ddsasa !
Mar 06, 2011 | Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
