Need a BOOT diskette
After more than a decade I found my old lEpson ActionNote 500c aptop in the closet and turned it on... the following message appears:
"DRIVE NOT READY ERROR
Insert BOOT diskette in a:
Press any key when ready"
I don't recall but think it must have been pre Windows 95 and I do not have a BOOT diskette. It is a relic and I like to see what's in the hard drive. What can I do?
Thanks,
Mike
    Sergeant:
    Champion:
  • 435 Answers
I am not sure if this will work. But worth a try.
http://www.allbootdisks.com/downloads/Disks/Windows_98_Boot_Disk_Download49/Automatic%20Boot%20Disk/Windows98.exe
download the link and create a boot disk (floppy)
Insert a blank floppy and run the exe file to create it.
You need to create this some computer having floppy drive.
Insert this disk into your laptop and boot using this disk.
You should be able to boot in dos prompt.
now, you could browse through the harddisk contents by accessing C: or D: or etc ....
I assume you know basic DOS commands :)
lemme know if it works .
Posted on Aug 06, 2008
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
How do i uninstall windows 98 plus from my computer
You simply can not uninstall an OS (operating system), you may have to Format the hard drive itself. If you are upgrading the OS to a version that uses NTFS, like windows xp or higher, a format is suggested. If you have a boot diskette, you can do it that way. If not you can create on using windows 98, but you will need an old floppy diskette and a drive to boot. If you have a newer OS on a CD, simply insert into the computer and follow the on-screen instructions.
If you have a boot diskette(floppy), turn off your computer. Insert the disk and turn on the computer. Let it do its thing, once the diskette loads small programs, you will be able to format the HDD(hard drive).
you will see something like this after its done loading...
c:\
type in format c:
shown like this...
c:\format c:
A message will pop up, saying: WARNING! ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with fromat? (y/n)
If you are sure you want to erase everything, type in Y. The computer will now format (may take awhile) and will be ready for a new operating system!
Jan 30, 2012 | Microsoft Windows 98 for PC
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
Ntldr cd boot fault
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again
Mar 31, 2010 | Computers & Internet
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Dell logo appears and message appears INSERT BOOT DISKETTE...
A couple of things can cause this.
1] having the 'boot order' set up so that the computer looks to a removable device that has non-bootable media in it.
2] somehow the 'boot' device has lost it's 'boot' properties.
Best way to troubleshoot:
1] find the boot CD
2] re-strat the machine and enter the "BIOS setup" mode <f10>, or <DEL>; I think::verify the boot order
this should likely be: C: ; CD ; A:
allow machine to start with CD and check to see if anything on the wanted 'boot' device has been lost; sometimes it will get smashed.
Let us know what you get after this point, because I would rather give you an answer based on knowledge from this part of the exercise.
Mar 21, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
No power to hard drive Fujitsu lifebook laptop
The new hard drive will not have an OS on it until you install one, so expect a no OS found message.
The old hard dirve may have lost its master boot record or the boot cylinder is bad.
You mentioned DOS. Do you have bootable DOS diskettes available?
First plug the old drive into the desk top and copy off any data you wish to save.
Depending on the operating system on the desktop and utilities available you might be able to recreate the master boot record on the old drive. Be very careful you know which drive is which or you could cause problems with the desktop drive.
You might also be able to run DISK MANAGER and test the drive for errors.
If you can boot the DOS diskettes the command you need to run is FDISK /MBR with the old hard drive installed.
Sorry, I really need a lot more info to be more specific.
Apr 10, 2008 | Fujitsu LIFEBOOK C2210A (AKA0F0A00B001000)...
Weird error message on boot. BIOS error?
This is a strange one. Does the BIOS on your motherboard detect your hard drives at all? I'd try the lowest level first. If so, then try to boot from your XP CD ROM (hopefully this should work). Try to go into recovery console to see if your hard drive can even be mounted by the system. I'd check there.
If you still have issues,try to reflash your mobo BIOS to the most current one. Could be a flaky BIOS issue.
Feb 06, 2008 | AMI American Megatrends UltraSCSI...
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
