Question about Nokia Wireless Bluetooth Headset Headset
I have a Nokia CE 0889 bluetooth, how can I connect to a phone?
How do I connect my Nokia 225 mobile phone to Hands free Nissan Note via Bluetooth
Hi, I had trouble connecting to a corsa with my Nokia, I Had to try serveral things to get it working. first of all is you phone bluetooth name visible?, is your bluetooth name different from other bluetooth device names stored on the car?
Have you tried a bluetooth search from the car to the phone and from the phone to the car?, did either or both devices ask for a pin number(usually 0000)? If you can offer anymore more infomation that would be great.
Mar 09, 2015 | Nokia Cell Phones
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
My Bluetooth device (CE 0979) has just stopped working. Green light flashes non-stop. How do I get it going again?
Turn off the Bluetooth device and turn off your phone. Turn your phone back On. In your phone go to Bluetooth and remove permission for the device. Re-start your phone. Turn your phone back on and pair your device. The passcode is probably 0000 (four zeros). Once paired it should work properly.
(Note: Make sure your Bluetooth device is fully charged before attempting to pair it.)
Feb 05, 2011 | Nokia E51 Cellular Phone
Hi sir I've an lg mobile model ce 0889 i need the sim unlocked code or mobile unlocked code pls solve my problem. Thanks,
sir please call to the related simcard customer care to get the pukcode number. you should say the last 6 digit number which is present before the simcard to the customer care.then they will give the puk code number to unlock the simcard........................
Dec 07, 2010 | Cell Phones
Bluetooth problem
just open the back of ur 6700 c pull the battery, memory card and sim!
now there you will see a unique code beneath the batary very right on the sticker of
IMEI and very next to the CE logo!
now just tap this unique code with the battery edge for about 20 times!
now put the memory card and sim card and battery back n enjoy Bluetooth working....
MDX
Nov 07, 2010 | Nokia 6700 Classic Cell Phone
Probleme avec bluetooth
where i can find my bluetooth driver for my hp pavilion dv4ooo
Jul 25, 2008 | HP Pavilion dv4000 Notebook
Does Nokia 6030 have bluetooth (plantronics 610)connectivity?
Please see the followoing page for all the spec's on your 6030.
http://www.phonescoop.com/phones/phone.php?p=700&fsm=1
(click show missing features to show all features)
Unfortunatly that model is not bluetooth capable, you can purchase a bluetooth transmitter for it, or upgrade the phone to one with bluetooth capability.
See this page for more info on bluetooth transmitters.
http://www.slashphone.com/106/1875.html
Good Luck and hope this helps
Jul 04, 2008 | Nokia 6030 Cellular Phone
Is IPAQ rz1710 bluetooth technology compatible or not ?
The 1710 does not have bluetooth. You would have to buy a SD bluetooth card and then you could connect to the internet via a bluetooth phone if the phone had internet access.
Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
Nokia Wireless Bluetooth Headset Headset Logo
442 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
