Question about OKI Office Equipment & Supplies
My oki c5650 is printing think black lines from top to bottom when i print out any document
SOURCE: occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
Posted on Nov 24, 2008
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
  • 157 Answers
SOURCE: i have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Posted on Nov 09, 2009
  • 240 Answers
SOURCE: Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Posted on Nov 29, 2009
Okidata c9650 printer. technician told me to replace transfer belt in my unit because i was having an issue with the color print quality. It had a light streak running through it and the top of the page...
That message is indicating that you need to replace the black drum which also may have been what was causing your origanal issue. Whenever you have a print quility issue print four seperate documents each document using one of the four colors (black, yellow, magenta, cyan)used by the printer. If the problem only shows up in one color then that is where the problem is coming from.
Jan 21, 2011 | OKI C9650HDN Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
We're seeing heavy pixelation on all of our prints.
I would try going to the color menu on the printer and performing the density and registration calibration that should cure your problem hope this helps.
Nov 25, 2009 | OKI C5650dn - 1212601 - - Laser Printer...
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
OKI C5200 - Faded black print area
Trying cleaning the black LED's that are on the top portion of the open clamshell. Use rubbing alcohol on a rag and wipe each bar x4/. These units charge the drum surface where print is going. This should work.
Jun 12, 2008 | Samsung OKIDATA - OKI C5200n - Printer
OKI C5200 laser printer
Delete driver, download latest from oki, reinstall, is this networked or USB?
Is printer free from error lights, check page settings.
more I think about it, it seems to be a network/driver issue.
If printer can stand alone print ok ie menu map, then it is either the cable but more often the driver.
Check IP config if network.
Fixya or post back
Jan 02, 2008 | OKI C5200n Laser Printer
Yellow Lines on every print
If the optics are clean (use lint free cloth on 4 rows of black thingys underside of lid)
Then it sounds like the yellow drum needs to be replaced, when printing in word I'm guessing that you have it set to B/W prints hence no colour is engaged, no lines
Oct 17, 2007 | OKI C5100n Laser Printer
120 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
