Outer door won't close message. The door is closing but doesn't seem to be full into the catch
    Master:
  • 354 Answers
Your gasket on the door has probably came out of it's groove,try that. Or the gasket is bad and not right on the door and won't let the door close or the hinge or the latch is misaligned.
Posted on Apr 05, 2011
Bosch sms63mo8au 12 door latch
Could be the latch that's attached to the top of the outer shell frame has become loose and is out of alignment, so its not able to close properly. Pull the unit out from under the countertop and have a look at whats happening with the latches when you try to close and lock the door. Adjust as need.
Aug 07, 2014 | Bosch Dishwashers
Door won't close on J845 front loader
Replace door lock. Also check tightness of hinge v
Nov 15, 2017 | Washing Machines
Drivers side sliding door won't close
check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
Jan 01, 2014 | 2004 Nissan Quest
2008 Dodge Caliber driver side front door won't close.
They have been a known problem and need to be lubricated often. There may even be a technical service bulletin on them , check with dealer for possibility of any partial extended warranty regarding those hinges.
Mar 30, 2013 | 2008 Dodge Caliber
Garage door won't go down all the way and then reverses to open
Check that the wheels and bearings are turning freely and that the door is not cocking to one side when closing. If the wheels are catching because of bad bearings, because the tracks are out of true or because the door is not staying straight in the tracks, the motor thinks that the door is hitting a car or a person and reverses. One thing to try: disengage the motor and try moving the door through the full traverse. Most automatic doors have a pull-cord that disengages the door from the motor. CAUTION: You may need a friend to help with the door, because it could be surprisingly heavy,.
May 01, 2017 | Chamberlain 3/4-HP Whisper Drive Plus...
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
The Driver's side door of our 1996 Saturn Stationwagon won't catch when you close the door. In otherwords, if I drove the car, I can close the door but it doesn't catch and therefore the door...
first make sure the bolts which hold the latch mechanism to the door are firmly screwed in. if that ain't it, remove the post which it clamps onto from the door jamb and switch it with one from a back door. close the back door firmly, lock it and never use it again. if that ain't it go to www.getsaturnparts.com and buy yourself a new door latch mechanism and pay an auto glass shop to put it in for you.
Sep 07, 2011 | Saturn SW2 Cars & Trucks
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
