Question about Ricoh Office Equipment & Supplies
How to install RICOH Aficio 2045eSP to network computer?
  • 928 Answers
First you have to check the IP address of the Ricoh. Normally it is on the display. Then you go to the computer in the network and then create a new printer in the printers and faxes then add a network printer and put in the IP that you need. Now another option would be to install the software on the network printer so that you can use the scanning functions.
Posted on Aug 06, 2008
  • Thomas Lim
    Thomas Lim Aug 06, 2008
    By the way my assumptions are that you are already on a network, normally if you plug in the printer it will automatically get an IP address depending on the network setup. If you need to manually set the IP you can check your manual on how to set an IP that is in range of your network. If someone is administering your network you may have to ask for an IP address that you can use.
    Brigadier General:
  • 3,614 Answers
Do you use a switch or a router on your area, and also may i know the OS that is installed on your PC..
thanks
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Hello I'm in Brazil can not resolve error in my SC990 Ricoh Aficio 2045eSP. This error pops up after 10 copies or printing. Already exchanged cylinder, blade, developer and toner new. Please help me.
Why change the drum, blade, developer ????? You had problems with print quality?? I think it was just spending money ....
You have a network problem or machine firmware. To remove the doubts plug a laptop directly to the machine with a cable (Not necessary a croos cable). This may be a virus network or a broken swith.
Good luck
Feb 11, 2011 | Ricoh Aficio 450 Copier
Hi, I have an RICOH Aficio SP C220N DDST installed on a school network. It is not connected to any computer but plugs into a network point & has it's owned fixed IP address. I installed it to...
Hi there. When you installed the drivers locally to each computer, you should be given the option to select the device as the default printer. I understand that you have not chosen this during your installation process. The best options would be to either install this driver on the server and/or use a logon script to set as the user's default printer upon each log on to their computers.
Jan 16, 2011 | Ricoh SP C220N Aficio Laser Printer
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 220 - Connection with computer
Please use the link below and scroll down to choose your Operating system, and download and install the printer driver.
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=241&ricohmodelid=5&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fhtml%5Fre%2Fmodel%2Faf22%5F27%2Faf22%5F27en%2Ehtm
Hope you have a printer controller type 270 installed on your Aficio 220, already.
It can be connected with a parallel cable or ethernet cable if you have a network card installed in the printer controller of the Aficio 220.
Good luck and please rate me, thanks.
Jan 24, 2009 | Ricoh Aficio 220 Laser Printer
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Steps to install RICOH 2045eSP printer, scanner, copier to network computers
ok.. please kindly wait.. i will re construct a procedure for you..
BTW.. your network was wired or wireless?
Aug 06, 2008 | Office Equipment & Supplies
195 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
