Question about smilebox.com
I have had a smilbox account for over a year. I am a teacher and use it continually for our profile folders. This week every time I have clicked on the smile box logo on my screen it comes up with the wording that i need to be connected to the internet. I am connected to the internet!! I am desperate to print some pages that i made up and I need them by tomorrow. Are you able to help me?? Kind regards, Sharon Steele
How to get computer off a tempory profile
which operating system ?
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
Tip
Vista - The User Profile Service failed the logon. User profile cannot be...
How to Fix the Error "The User Profile Service failed the logon. User profile cannot be loaded."Information. When you log on to Vista using a temporary profile (user account), you receive this error message:For more information, KB947215.The User Profile Service failed the logon. User profile cannot be loaded Note Warning If you have this error message below instead, then see: How to Fix the Error "Your user profile was not loaded correctly! You have been logged on with a temporary profile." in Vista Your user profile was not loaded correctly! You have been logged on with a temporary profile.Changes you make to this profile will be lost when you log off. Please see the event log for details or contact your administrator.Tip. If the steps in the tutorial below do not help or you wish to try this first, then: You can try doing a System Restore at boot to see if it can fix this before using the instruction in the tutorial below. If you do not want to repair the user profile, you can delete it and create a new user account in OPTION TWO. If this still does not work for you, then you will be left with doing a clean install for your Upgrade or Full version of Vista.Try the option at this link: Rob Brooks-Bilson's Blog: Fix for Vista's: The User Profile Service service failed the logon. User profile cannot be loadedSTEP ONE:Logon to the ComputerWarningYou must be logged on to an administrator account from step 1 or 2 below before you can move on to do either the OPTION ONE or OPTION TWO sections.1. Logon to another Administrator account. NOTE: If you do not have another Administrator account, then proceed to step 2.A) Go to OPTION ONE or OPTION TWO.2. Boot into Safe Mode. NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account.A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.B) Logoff in Safe Mode, and then logon to the built-in Administrator account to logon with that account in Safe Mode.C) Go to OPTION ONE or OPTION TWO.OPTION ONE:Fix the User Account Profile1. Open the Start menu.2. In the white line (Start Search) area, type regedit and press Enter.3. If prompted, either click on Continue or enter the password for the Administrator account.4. In regedit, 5: Code: HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionProfileList5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers. (See screenshots below steps 6A and 7B (NOTE: A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.6. For Two S-1-5..... folders (SID key) with the same Number -NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (B) Add .bk to the end of the numbers. C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. D) Remove only .bak from the end of the numbers and press Enter.E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter. F) Go to step 8.7. For Only One S-1-5..... Folder (SID key) with .bak -NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)B) Remove only .bak at the end of the numbers and press Enter. 8. In the right pane of the one without .bak now, right click on RefCount and click on Modify. NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter. This value for this entry will reset and return back to the original value after you have restarted the computer and logged on to the account.A) Type 0 (number) and click on OK. 9. In the right pane of the one without .bak now, right click on State and click on Modify. (See screenshot below step 10)NOTE: This value for this entry will reset and return back to the original value after you have restarted the computer and logged on to the account.A) Type 0 (number) and click on OK. (10. The registry will now look like this for the one without .bak now. (See screenshot below)11. Close regedit.12. Restart the computer.13. See if you can logon now.NOTE: If this still does not help, then either try OPTION TWO below or see the yellow TIP box at the top of the tutorial.OPTION TWO:Delete the User Account ProfleWarningYou can do this option if you do not care about losing the user account and the contents in the user folders. Your programs will still be installed, but you will need to create new shortcuts for them afterwards. 1. Delete the User account profile that this error is for.NOTE: See: How to Delete a User Account in Vista2. Open the Start menu.3. In the white line (Start Search) area, type regedit and press Enter.4. If prompted by UAC, click on Continue.5. In regedit, go to: Code:HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionProfileList6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it. NOTE: It may have .bak at the end of it.A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.B) Repeat step 6 until you find the one that you deleted in step 1 above.NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.7. To Backup the Registry SID Key -WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.A) Right click on the SID key, and click on Export.B) Type in a name and save the REG file to a safe location. NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click on Merge.C) Continue on to step 8.8. To Delete the Registry SID Key -A) Right click on the SID key, and click on Delete. B) Click on Yes to confirm deletion.9. Close regedit.10. Now, just create a new normal Administrator account.NOTE: See: How to Create a New User Account in Vista11. Restart the computer, and log on to your new account.NOTE: If this still does not help, then either try OPTION ONE above or see the yellow TIP box at the top of the tutorial.
on Feb 11, 2010 | Computers & Internet
Tip
How to copy data from a corrupted user profile to a new profile
Create a New User Profile in Windows XP Professional loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Click the Advanced tab, and then click Advanced. 5. In the left pane, click the Users folder. 6. On the Action menu, click New User. 7. Enter the appropriate user information, and then click Create
Create a New User Profile in Windows XP Home Edition loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Under Pick a task, click Create a new account. 5. Type a name for the user information, and then click Next. 6. Click an account type, and then click Create Account
Copy Files to the New User Profile loadTOCNode(2, 'moreinformation'); 1. Log on as a user other than the user whose profile you are copying files to or from. 2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK. 3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from. 4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat • Ntuser.dat.log • Ntuser.ini 5. On the Edit menu, click Copy. 6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section. 7. On the Edit menu, click Paste. 8. Log off the computer, and then log on as the new user.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
•Guests
•Domain Guests
1. Click Start
or
hope this helps
or
hope this helps
I wish to delete Match,com
Hi and welcome to FixYa!
If you are wanting to delete your account;
Log in to Match.com, and click the "Account" link at the top of the screen.
Click "Change/Cancel Membership.
Enter your password, and click "Continue Cancellation."
Click "Cancel Membership and Remove profile." Your Match.com account is canceled, and members can no longer view your profile. However, the profile will be saved for one year in case you would like to reactivate it.
good luck!
KittyTech
Sep 07, 2011 | Yahoo Mail
Tip
This article describes how to copy user data from your Windows XP profile to a new profile.
When you copy user data into a new profile, the new profile becomes a near duplicate of the old profile, and contains the same preferences, appearance, and documents as the old profile. If your old profile is corrupted in some way, you can move the files and settings from the corrupt profile to a new profile.
Note The method that is described in this article may not transfer the Outlook Express e-mail messages and address user data that are associated with the user profile where you are transferring data from. When you delete the old profile, you may delete that data if it you do not first transfer it by using other methods. For more information about transferring Outlook Express user data, click the following article number to view the article in the Microsoft Knowledge Base:
MORE INFORMATION
7. Enter the appropriate user information, and then click Create.
6. Click an account type, and then click Create Account.
• Ntuser.dat.log
• Ntuser.ini
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Want to delete match.com
Hello
Here is how to do this;
Click "Change/Cancel Membership."
Click "Cancel Membership and Remove profile." Your Match.com account will be deleted, and members can no longer view your profile
However note that,your profile will be saved for one year in case you would like to reactivate it.
Thank you for visiting fixya
Apr 21, 2010 | Yahoo Mail
Vista wont let me log in
How to Fix the Error "The User Profile Service failed the logon. User profile cannot be loaded." Information. When you log on to Vista using a temporary profile (user account), you receive this error message: For more information, KB947215. The User Profile Service failed the logon. User profile cannot be loaded Note Warning If you have this error message below instead, then see: How to Fix the Error "Your user profile was not loaded correctly! You have been logged on with a temporary profile." in Vista Your user profile was not loaded correctly! You have been logged on with a temporary profile. Changes you make to this profile will be lost when you log off. Please see the event log for details or contact your administrator. Tip. If the steps in the tutorial below do not help or you wish to try this first, then: You can try doing a System Restore at boot to see if it can fix this before using the instruction in the tutorial below. If you do not want to repair the user profile, you can delete it and create a new user account in OPTION TWO. If this still does not work for you, then you will be left with doing a clean install for your Upgrade or Full version of Vista. Try the option at this link: Rob Brooks-Bilson's Blog: Fix for Vista's: The User Profile Service service failed the logon. User profile cannot be loaded STEP ONE: Logon to the Computer Warning You must be logged on to an administrator account from step 1 or 2 below before you can move on to do either the OPTION ONE or OPTION TWO sections. 1. Logon to another Administrator account. NOTE: If you do not have another Administrator account, then proceed to step 2. A) Go to OPTION ONE or OPTION TWO. 2. Boot into Safe Mode. NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C. B) Logoff in Safe Mode, and then logon to the built-in Administrator account to logon with that account in Safe Mode. C) Go to OPTION ONE or OPTION TWO. OPTION ONE: Fix the User Account Profile 1. Open the Start menu. 2. In the white line (Start Search) area, type regedit and press Enter. 3. If prompted, either click on Continue or enter the password for the Administrator account. 4. In regedit, go to: (See screenshot below step 5) Code: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList 5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers. (See screenshots below steps 6A and 7B) NOTE: A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error. B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it. 6. For Two S-1-5..... folders (SID key) with the same Number - NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers. A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. ( B) Add .bk to the end of the numbers. C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. D) Remove only .bak from the end of the numbers and press Enter. E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter. F) Go to step 8. 7. For Only One S-1-5..... Folder (SID key) with .bak - NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers. A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below) B) Remove only .bak at the end of the numbers and press Enter. 8. In the right pane of the one without .bak now, right click on RefCount and click on Modify. NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter. This value for this entry will reset and return back to the original value after you have restarted the computer and logged on to the account. A) Type 0 (number) and click on OK. 9. In the right pane of the one without .bak now, right click on State and click on Modify. (See screenshot below step 10) NOTE: This value for this entry will reset and return back to the original value after you have restarted the computer and logged on to the account. A) Type 0 (number) and click on OK. ( 10. The registry will now look like this for the one without .bak now. (See screenshot below) 11. Close regedit. 12. Restart the computer. 13. See if you can logon now. NOTE: If this still does not help, then either try OPTION TWO below or see the yellow TIP box at the top of the tutorial. OPTION TWO: Delete the User Account Profle Warning You can do this option if you do not care about losing the user account and the contents in the user folders. Your programs will still be installed, but you will need to create new shortcuts for them afterwards. 1. Delete the User account profile that this error is for. NOTE: See: How to Delete a User Account in Vista 2. Open the Start menu. 3. In the white line (Start Search) area, type regedit and press Enter. 4. If prompted by UAC, click on Continue. 5. In regedit, go to: (See screenshot below step 7) Code: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList 6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it. NOTE: It may have .bak at the end of it. A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above. B) Repeat step 6 until you find the one that you deleted in step 1 above. NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9. 7. To Backup the Registry SID Key - WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below. A) Right click on the SID key, and click on Export. B) Type in a name and save the REG file to a safe location. NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click on Merge. C) Continue on to step 8. 8. To Delete the Registry SID Key - A) Right click on the SID key, and click on Delete. B) Click on Yes to confirm deletion. 9. Close regedit. 10. Now, just create a new normal Administrator account. NOTE: See: How to Create a New User Account in Vista 11. Restart the computer, and log on to your new account. NOTE: If this still does not help, then either try OPTION ONE above or see the yellow TIP box at the top of the tutorial.
I have a dell latitude d610 lap top
Based on the build of a D610, I am assuming you're running Windows XP. I'm not sure your hardware can support Vista. That model was built before Vista was available.
That said, go to Start-Control Panel-User Accounts. Most likely a setting in there was changed, and my first thought is that it may have been after a Windows Update, in an effort to increase security.
See if the user you're trying to login with even shows on the list. If it does, click on it and change the password to <blank>.
If that user no longer shows then you will have to rebuild the profile for that user. I will caution you that if you have to rebuild the profile, you would want to make copies of the data attached to the old profile. You can do this from Windows Explorer. Start by making sure you can view all files. Then navigate to Local Disk C:-Documents and Settings, then to the folder for that username. Copy all of the folders and files to a safe place, like burn it to CD's or DVD's, or even to a flash drive. Do not save it to My Documents.
Sometimes the fastest way to rebuild the profile is to actually create a new one. Set it to administrator access. Then you can copy the contents of your old user's folders (but not the folders themselves) into the new user's folders.
Here's a recap:
1. Log in as admin or an account with admin permissions.
2. Select the windows START button and click CONTROL PANEL
3. Click USER ACCOUNTS
4. Select CREATE A NEW ACCOUNT. You may need to select pick a task first
5. Type in a new name for the account
6. Click create account and ensure it is an admin account.
4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: Ntuser.dat, Ntuser.dat.log, Ntuser.ini
Jun 10, 2009 | Dell Latitude D600 Notebook
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
NOTE : Go down the list here until you find a option that will work for you.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
OPTION ONE:
NOTE:
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
F) Go to step 8.
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
11. Close regedit.
OPTION TWO:
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
4. If prompted, click on Continue.
A) Right click on the SID key, and click Export.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
11. Restart the computer, and logon to your new account.
Good Luck.
Live, Love, Laugh.
Sep 11, 2008 | Dell Inspiron 1521 Notebook
smilebox.com Logo
Top smilebox.com Computers & Internet Experts
ray gallant
Tony Mitri
Are you a smilebox.com Computer and Internet Expert? Answer questions, earn points and help others
