Question about Garmin eTrex Vista GPS Receiver
It has stopped working, There is no power. I have put new batteries in but it doesn't seem to work.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Have you contacted Garmin directly yet? There website is www.garmin.com When you get to the page go to the top right hand corner of the page and click My Garmin. If you don't have a username and password you can set up one there. You need to contact Garmins technical support either by email or by telephone. It sounds to me that you have a internal component failure and I would suggest you send it to them for repairs. When you contact Garmin ask them what it would cost to look at your unit and repair your unit.
I hope this helps you out if so please give me a yes that you were helped with your problem. Thank you.
Posted on Apr 05, 2011
Radio doesn't work on batteries
same problem here, but with my radio shack scanner. When I disconnect the cord, however, the low battery indicator symbol comes on for a bit so radio seems to be taking in juice. May try a better brand of battery or some rechargeables.
Apr 30, 2013 | C. Crane SWP AMFM Radio
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Battery level quickly empty
I recommend you to buy a new battery. If this doesn't work. Just buy a new Camera, because the engine probably broke.
Dec 28, 2011 | Olympus SP-570UZ Digital Camera
Ommy st503sm stopped firing however put in a new battery but there is now no power to starter and neutral light doesn,t come on now even tho it,s not in gear all lights work
chec connects make sure theyr clean and tite-specialy batt--inspect for loose grounds--may need to test complete ignition-relays/switches/points
Aug 12, 2011 | 2008 Skyteam ST50
I have a Sony Handicam (model dcr-dvd108) and I haven't used it in a few months. I tried turning it on but it turns off after about 10 seconds. Also the the place where you put the disc doesn't...
Base from the description of your problem it seems that the unit encounter a mechanical failure because of not being use for a long period of time.
What we can try here first is to do a reset on your unit, you can do that by pressing the reset button using a pen or a paper clip for 30 seconds and then power OFF and power back ON the unit and see if that will correct the issue also when you power it OFF you take the battery out for 1 minute then put it back in and power ON.
Jun 28, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
Treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
Oct 20, 2007 | Palm Treo 650 Handheld
Garmin eTrex Vista GPS Receiver Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
