Question about VOX Amplification JamVOX Guitar Jam and Practice Tool( )
Computer crashes with jamvox monitor plugged [ into usb slot] or on start and restart-Windows Vista[Home] service pack 2
2 Suggested Answers
  • 5603 Answers
SOURCE: my jamvox program was working
Check in the control panel "sounds and devoces" under several tabs including "Voice" that the JamBox device is shown selected and not muted.
Posted on Feb 18, 2011
I plug the USB from the D888 to my laptop (Toshiba Satelitte with Windows Vista) and nothing happens. The USB button is turned on.
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
Mar 23, 2013 | Korg D888 8 Track Recorder
The problem I have is the following: I have a powercore firewire and a powercore compact. They were sounding perfect until I bought three plug-ins: the TubeTech CL-1B, Tap Factory and Harmony 4. At...
Remove the offending plug ins and test. Then install one at a time and test. You may be running out of processing power to service all of them. Each effect requires a lot of computer resources. Look at your system idle time when you do a CTRL-ALT-DEL and click on the processes tab while running the plugins. The last item in the list is the system idle time. If this number is small, you are out of computer power and or resources.
Jun 05, 2011 | TC Electronic Helicon Harmony4 Harmony 4...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
I have a M-Audio keystation 61es. When I plug it in to the USB, the advanced functions LED and both the octave LEDs come on, but the computer does not recognize the device. I have already downloaded the...
These are just some ideas to think about:
SOME drivers for PC's require the device to NOT be plugged in until the driver has been loaded and restarted.
SOME drivers for PC's require that the driver be installed in SAFE MODE.
IF you are using Vista or Windows 7 check compatibility as there are MANY issues with compatibility with these operating systems.
Sometimes the manual doesn't emphasize these points so just a reminder here to check these things out. Worst of all, sometimes the manuals do not tell of the quirks, so search the forums about the issue.
Here is a site talking about M audio and having to have driver installed first:
http://forum.recordingreview.com/f9/m-audio-fast-track-pro-driver-problem-3544/
If you had it connected, you may have to un-install it completely before re-installing...
Mar 02, 2010 | Music
Samson c01u vista drivers
No. From their website...
Note: Samson SoftPre is not compatible with Windows Vista however the C01U, C03U and Q1U are all Plug-and-Play compatible with Windows Vista.
Aug 15, 2009 | Samson Audio C01upak C01u Microphone and...
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
VOX Amplification JamVOX Guitar Jam and Practice Tool( ) Logo
148 people viewed this question
Top VOX Music Experts
rhodesworks
Tom Chichester
Are you a VOX Music Expert? Answer questions, earn points and help others
