Washing machine not spinning reading error F-11
    Novelist:
  • 99 Answers
The F11 code is a loss of communication between the CCU circuit board and the MCU circuit board. The problem is bad solder joints on the CCU (also known as cold solder joints) The cure is to remove the CCU (inside machine, top, back, plastic case) remove the case then the circuit board, it's easier that way. Then touch-up the connections for the spade connectors and the relays (5 of them) If you're not up on soldering techniques, just take the CCU and this response to a good appliance repair store and they should be able to help you out. Good luck.
Posted on Apr 09, 2011
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Code error for my front loadef panasonic washing machine reads U 11
U codes are User "Error" Codes.
CODE U11
The washing machine cannot drain.
Check that filter is not blocked or obstructed.
Check drain hose is clear of any blockage or obstruction.
Check wiring to drain pump (Done only by a Service Technician.)
Check drain pump is not defective (Done only by a Service Technician.)
Check level sensor or switch (Done only by a Service Technician.)
Check wiring to level sensor (Done only by a Service Technician.)
Many Panasonic washing machines seem to have a problem spinning with heavy loads; they become unbalanced and give a U13 "load out of balance" code. Most other brand machines can spin the same "heavy" load with no problem.
Mar 11, 2013 | Washing Machines
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Oct 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Whirlpool Duet Washer
Jake at applianceblog says that the F11 is a "Serial Communication Error"
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed.
Nov 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
