When i turn on my yamaha f20 guitar amp, it produces a hissing/ static radio sound. Is it the power capacitor or something else?
    Novelist:
  • 151 Answers
Possibly interference from another electrical source. This can be compounded by high gain or the use of a distortion pedal. Try moving the amp to the middle of the room or away from things like appliances, lighting dimmer switches computer, tv etc.
Hope this helps.
Posted on Apr 05, 2011
Behringer ac 112 guitar amp powers up, display works. dials act normally, but no sound. only static as volume turned down (speaker works). amp was left on for long period
Try putting guitar trough the FX Loop, if there is still no sound, you may have a problem with the Power Supply.
Oct 01, 2013 | Music
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
I turn my fx off but can still here it and the od sound is lower than the fdx button when i push it in to turn it on
2 things 1: there is no off button for the built in digital effects, you just turn the level down to minimum, the fdx button you speak of is actually fdd (frequency dependant damping) this is supposed to mimic how a tube amp sounds
2: when you press the od switch the amp goes into hi gain mode and will hiss with no input, the point is if you plug a guitar in and play it the volume of the guitar is way above the hiss and you don't hear it
so in conclusion having bought and sold many mg series amplifiers the on you have is perfectly ok
Mar 10, 2012 | Marshall Mg15dfx 15-Watt Combo Guitar...
Vox mini3 hiss or white noise when reverb or delay is selected.
The way I've found this amp works is it always needs a certain amount of "Gain" from the gain nob in order to produce any sound.Unfortunately the more gain the more hiss and crunch at least thats been my experience, it could also be you have one of the filters "guitar sounds" left on.The guitar sounds nob has to be left on clean to attain pure clean.There could also be a connection problem.I have this at the moment.I have to bend my wire in the right place to keep the thing going.Another issue I have with his amp is its been replaced my first one just conked out completely I couldn't get the cash back when I asked so I just got another one.This new ones been fine but not without hiss.I think its a hissy amp I hate to say it.Not the best amp by a long shot.
Oct 13, 2011 | VOX Amplification Vox MINI 3 Amp Combo
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Mar 10, 2010 | Yamaha Music
Yamaha g100-112 guitar amp.power light comes on no sound.Transistor heat sink cold
do you have a low hum from the speaker when u turn it on? if no, then take it to the repair tech. probably power on indicator is okay but power supply does not reach the pre-amp or the power amp section. case maybe bad filter capacitor or bad series power line resistor. get it checked. i sincerely doubt internal speaker loose connections.
Mar 07, 2010 | Yamaha Audio Players & Recorders
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
Roland AC90 crackles when using a slide.
It is because the AC-90 is not grounded. If you look at the power cable, there is just + and -, no ground/earth. This is because ground is not usually needed when using acoustic guitars/ mikes. If you use an electric guitar, or a slide, there will be problem. I have a AC60, that does go to ground. No hum. AC90=hum. Can probably be fixed by attaching new power cable and soldering earth to the chassis, like on the ac60.
Jan 27, 2009 | Yamaha AX-596 Amplifier
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
 Grubhead
Grubhead
