Question about Microsoft Office Professional 2007 Full Version for PC
How can i install my printer as default on my so that print
    President:
  • 2,340 Answers
From your "Start" ->Go to "Printers & Faxes" -> Right-click on the "PRINTER" and click "Set to Default"
Posted on Apr 05, 2011
Problem encountered installing rhe new printer canon MX 360
Make sure printer jobs are cleared and try printing again. Delete any stuck or error'd jobs. Also confirm that it is the default printer. It should have a check indicating so in printers. You can assign default by right clicking and choosing set as default.
Aug 28, 2012 | Office Equipment & Supplies
I have connected my PC to the printer (Thoshiba e-studio 16) i installed software manually, but i am not able to print my document, i need help.
checked the manual on how to install the driver of the printer,then after installation, go to start menu then click setting then go to printer and faxes, then you see the printers installed in your computer, right clicking your installed printer then set us default printer. you can print also a test page by right clicking your installed printer the click properties the test page print...
see the attached sample picture on how you set as Default Printer and go to the properties of the printer...
Mar 04, 2011 | Toshiba Computers & Internet
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
What procedures should I follow to install a wireless canon laser printer MF 3110 into my windows Vista computer
Install the drivers/software onto PC that you want to print from.go to Start Printers and Faxes look for the printer either set as default or if not when you want to print to this printer you will have to choose it from drop down menu on print.If you plan to only use this printer choose Default if you plan to print by PC to Printer by direct usb you can choose default for PC and Default for Laptop wireless.
Depending on your Home Network you may be prompted for your network code.Note Without PC having wireless you wont be able to print to wirless printer,wireless,wired (usb will be fine).Good Luck.
Sep 05, 2009 | Canon MF3110 All-In-One Laser Printer
It just quit printing and copying
Hi ..
There could be multiple reasons for your printer not printing ..
1) Your printer is not setup as default.
2) Your printer drives need to be re-installed.
1) Your printer is not setup as default: If your printer is not your default printer, follow the instructions below to make it as default printer,
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' On the screen, right click your printer and then left click on "Set as default" option.
2) Your printer drives need to be re-installed: If you have the driver CD then use it to re-install the software.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer prints very slowly from computer e-mail
Trouble Shooting steps:
1)Open Internet Explorer
2)Tools >> Internet Options >> Advanced >> Restore Defaults
Now Try to Print Issue would resolve if this issue still persists follow this below steps,.to install Universal Printer Driver
1)Install alternate Driver Deskjet 990c
2)Click on Control Panel
3)Click on Printer and faxes >> Add printer >> Select Deskjet 990c >> Install the printer >> Make it as Default Printer Now
try to print your issue should resolve.
Feb 06, 2009 | HP Office Equipment & Supplies
Printer instalation
Good day.
Usually that happened once the printer was not set to default setting after it was installed.
To set to default, click start, choose printers and faxes, select the lexmak pinter, click file select default printer.
To test your printer if it print.
1. right click the printer icon
2. select properties
3. click print test page
Thanks.
Nov 01, 2008 | Lexmark X6570 InkJet Printer
Printer problems
hi, you mentioned that your default printer is the xps document printer. if you already have a 5300 printer icon, you can simply right-click on it and left-click on set as default printer to make it your default. but if you still dont have an icon yet, better still, call kodak tech support at 800.421.6699 so they could assist you in generating one
Oct 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer
If you are using only text print, you can install windows default laser jet printer.
This default printerdriver will not print your graphical out put,
Dec 26, 2007 | HP LaserJet 1020 Printer
Printing from Server applications
Is this printer set up as the default?
Try
file
Print
right click on the printer
go to properties
set as default
Sep 10, 2007 | Lexmark T642 Laser Printer
Microsoft Office Professional 2007 Full Version for PC Logo
15 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
