Question about Sharp CS-2850 Calculator
Casio FR-2650A I'm having the same problem. I have paper rolled from bottom, folded 2", but it still won't budge? Anything else I could try?
I have lost my manual. I can I thread my Casio Calculator FR2650a?
Posted on Mar 08, 2011
How do i feed the paper of the casio fr 2500 printing calculator
Hello Michel Dekock,
Could not find your FR2500 (but close)...
Has worked every time for me...
Mount the paper roll on the wire bracket... feeding
over the top of the ROLL (TOWARD THE MACHINE).
With the keyboard FACING away from yourself
Fold the FRONT EDGE of the PAPER on to the
side to form a chisel point... and insert the point
(folded side up) in the rear roller slot (paper feed)...
As shown on FR2650
http://www.ebay.com/itm/Casio-FR2650TM-Printing-Calculator-FR2650TM-/122298781152?hash=item1c79934de0:g:bwEAAOSw44BYbWjv
With the PRINT feature turned on the roll should be
advancing while holding down the TOTAL key...
Hold the key until the edge of the paper roll emerges from the machine.
Hope that helps.
(now you only have to freshen up the ink).
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
Mar 27, 2017 | Casio Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Operation instructions
Manual Center has the manual available here: http://www.manualscenter.com/manuals/casio/fr2650a-owner-manual.html#.VP9lNuOFr3g . You may be able to read the manual without paying for a downloaded copy. (The manual page images are on-screen but the font is small.)
I hope this helps.
Mar 10, 2015 | Casio FR-2650A Printing Calcultor P/N:...
Casio FR-2650A Not Pulling Paper Through
See if the roller gear is jammed or rusted. A little wipe with WD40 may help.
Jan 27, 2012 | Casio FR-2650A Calculator
How to install adding machine tape to a radioshack EC-3033
Here is the link to the instruction book for that calculator. It describes how to install the paper into the machine. The only thing I could recommend different is to fold the lead edge of the paper to a 45 degree angle /| instead of the straight edge the book is recommending. Sometimes there is a small blockage in the feed path and the angled fold will get the lead edge passed it enough for the feed rollers to catch the paper. The blockage usually feeds out with when the edge of the paper clears the rollers. I would try it by the book first then try the folded edge. The only other option would be a middle fold /\ in case the blockage is on the edge you folded from in the first attempt
Link to EC-30333 book
http://support.radioshack.com/support_radios/doc46/46048.htm
Hope that helps
Jun 12, 2010 | Casio FR-2650A Calculator
HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Jul 18, 2009 | Casio FR-2650A Calculator
FR-2650 Plus adding machine
How to install paper tape on a adding machine?
Apr 27, 2009 | Casio FR-2650A Calculator
Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Aug 30, 2007 | Sharp CS-2850 Calculator
Load paper
You must feed it through the back of the machine while depressing the feed key. make sure it is the right size paper and hopefully there is not a jam in the machine. If so you can try sliding a business card through the slot where the paper goes and force any jammed paper out of the path.
Jun 01, 2007 | Casio FR-2650A Calculator
Sharp CS-2850 Calculator Logo
192 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
