Question about Samsung HLT-5075S Television
Small White Dots on the Screen
I have the DLP 50" Samsung TV ( Model # HLT5075S)and have a problem with small tiny white dots appearing on the screen, at first it was only two and now we have apprx 30, I have been told it could be the DMD Board or the Lamp, Where do you purchase the replacement parts for this TV, I have been told we could replace the Lamp ourselves is this true ? how do I know the Part # for the DMD Board for this model ? Thanks for your help... the TV is only apprx 14 months old... Judy
  • 1 more comment
  • Anonymous Jan 21, 2009
    I had the same problem you need to go to www. partstore.com part 4719-001981 good luck
  • moak_rory Feb 05, 2009
    I am suffering the same issue. The DMD board is producing thousands of white, gray, and eventually black spots. If you have a warranty, use it. The cost of replacement is at least 950.00 with a 350.00 refund if you send them the core. Good luck. PS....dont wait to fix it, it will spread on your screen faster and faster :(
  • sleitch4 Mar 12, 2009
    SAME AS STATED WHITE DOTS ON SCREEN TRY REPAIR SITE WWW.JANGRO.COM
Just happend to my tv,i had a tv repair guy come out he wanted to charge me 600 to fix the tv is only 14 months old.
I ordered the part I need but now Im trying to find a manual to see if I can install or if i need to call someone to install
The part you need is 188.95 you an find it at http://www.partstore.com/ part number 4719-001981 it is the DLP Chip
Good Luck if I find out the install i will let you know
Posted on Jan 21, 2009
  • FAU Engineer Jan 25, 2011
    I got burned by InterLiquids for purchasing a used BP41-00289 DMD board. I sent it back to them and they sent my another board where both had white dots. One of the boards even had some corrison built up on it. NO REFUND, Go Figure!!!
    New Friend:
I have the white dot problem and had someone who knows look at it and they said it was not a board or lamp...it was burn dimples on the film that the mirrors shine on. I need to know where to get the film that the repair person said could be replaced.
Posted on Jun 26, 2012
  • jim watt Jun 26, 2012
    I have the white dot problem with the Samsung HL-T5075S and had someone who knows look at it and they said it was not a board or lamp...it was burn dimples on the film that the mirrors shine on. I need to know where to get the film that the repair person said could be replaced.
Shellie is 100% correct - my father's TV had the exact same problem. I purchased the part Shellie recommended and then purchased a service manual for $10 online. It's an easy fix and you don't have to be technically savvy to fix. Thanks Shellie!!!!
Posted on May 30, 2009
SOURCE:
Small white dots have started to appear on our screen, first, on, then a couple days later 2 more, and today we have 6 small white dots on our screen. What is happening to cause this condition?
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
Sep 25, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Three small white dots have appeared on the screen. What does it mean, is the lamp going bad?
White dots are caused by the DLP chip failing.This part must be replaced to get rid of the white dots. Samsung is covering the cost to repair this problem on several models. Ypu can call 1-800-samsung to find if your unit is covered.
Oct 06, 2010 | Samsung HLN617W 61" Rear Projection HDTV
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on Samsung 50* Model
Yes, It is problem with DMD module in light engine that will be replaced.
Hope Samsung will help you in replacement. Please update about outcomes.
Thanks.
Sep 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLT-5075S Television Logo
2,128 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
