Question about Cell Phones
Samsung gt s3250 touch screen does not respond at all. i can give the pin number n open the phone. But All buttons work fine
SOURCE: Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Posted on Sep 30, 2009
SOURCE: Samsung tocco lite touch screen..
this is a factory fault that cannot be rectified, from time to time the phone will freeze and after a while will function normally as if nothing ever happened. leave the phone alone dont fiddle with it until it resumes normal function
Posted on Apr 08, 2010
  • 1382 Answers
SOURCE: MY SAMSUNG GTS5233A'S TOUCH SCREEN IS NOT RESPONDING TO TOUCH.
The mobile screen would have been damaged or a device connected to your screen my be defected .Try to remove your touch screen safe guard sticker then clean the display. If this doesn't work out for you consult your dealer for replacement of new display.
Thank you !!
Posted on Jun 17, 2010
SOURCE: The touch screen of my samsung GT-S5230 phone is not
my gt-s5230 touch screen stop working. how can i reset it?
Posted on Sep 19, 2010
SOURCE: Samsung star touch screen mobile GT-S5233 touch
Samsung star touch screen mobile GT-S5233 touch screen is not responding pls guide me to resolve this issue.
Posted on Feb 23, 2011
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
Touch screen is not working
your first and last solution is just to bring it on the samsung sevice or if you have much just buy a new one ! :D
May 13, 2013 | Samsung Galaxy Ace Gt-s5830i - Black...
Dear, I have samsung Mobil GT s5223a But Touch screen Not working Properly , that is menu bar , and some times hangs on . Two or three days after switch on it is working the menu key after one or two...
Welcome to Fixya.
Things that may cause the touchscreen not to respond:
  • Check if there are no damages on the touch screen area
  • Make sure that the phone has never been dropped.
Solution:
  • Turn off the phone then take the battery out.
  • Press and hold the power button for 15secs then put the battery back in.
  • This will reset the software of the phone if the problem is software only.
If still screen is not giving any response then the issue would be more of an internal hardware problem. Here's a link to help you further test the issue.
Thank you for using Fixya!
Jun 17, 2011 | Samsung Star GT-S5233 Cell Phone
My Samsung star GT-S5233W's touch screen is not responding. I tried restarting the phone and removing the battery, but there's no response when I touch the screen with a finger or with a stylus. The outer...
The usual solution for such a problem is to have your phone's digitizer or touch screen replaced. That is the only solution for your phone's touch screen to work again. Have this done by a cell phone specialist, preferably one who's good with samsung phones.
Apr 09, 2011 | Samsung Star GT-S5233 Cell Phone
My calibration were offset
Good morning,
I have a problem with my Samsung cell phone, its a GT-S5233A touch screen. The problem that I have is the touch screen seems to have shifted down about 1.5cm so I am unable to access my keypad, phonebook or menu. I have tried taking the battery off but then battled to put in my pin as the numbers on the keypad have also shifted. I aqlso tried the recalibration but that just froze.Please assist.
Thanks
Brian
Aug 28, 2010 | Samsung Star GT-S5233 Cell Phone
Thank you !!
Jun 17, 2010 | Samsung Star GT-S5233 Cell Phone
Samsung s5233 touch screen not working
There is a simple answer to this and that is to replace the phones digitizer or touch screen and your problem solved.
br,
www.phonefreedomjamaica.net
Apr 11, 2010 | Samsung Star GT-S5233 Cell Phone
Cell Phones Logo
229 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
