Question about Yahoo Messenger
I want to sign in my id on mobile but when i click messenger and after that sign in to mobile device after that i select the country and i fill my no. in the blank box with country code and hit enter so it shows "We are unable to support the number that you have provided at this time." but if i fill another no. so its working but i want to fill my no. . so pease tell me its solution.
  • 4 Answers
Once you get the right number format, it will accept it ! For US numbers as an example use 1-AAA-PPP-LLLL where AAA is area code PPP is Prefix and LLLL is line number ...
Posted on Feb 06, 2013
  • 942 Answers
SOURCE: New problem in signing in Y! messenger. Help me plz
you can check you mail by using this, you can go directly to yahoo mail, you just open an internet explorer, after that you can type in the address bar, www.yahoomail.com, the type your user account and sign in then check your email's
Posted on Jun 30, 2009
  • 56 Answers
SOURCE: i cannot connect to yahoo messenger, it says,
May be ur entering wrong password or id.....click on forgotten password....if u remeber ur correct mail id enter ur mail id....or u can answer the two questions and enter your date of birth.....if u enter it correctly it will let u change ur password n u can agin login using new password......hope this helps....
Posted on Mar 11, 2010
  • 36 Answers
SOURCE: Hi i downloaded yahoo messenger 10 it is installed
.....try uninstalling messenger l0 and then re-installing it.....
Posted on Mar 24, 2010
addic_rocks
  • 130 Answers
SOURCE: iIssue
well first you just change the password all right.. now you uninstall your older version.. restart your PC
then install fresh new setup of newer version.. then try.. your problem will get solved..
Posted on Jun 04, 2010
male_28_cam
  • 1555 Answers
SOURCE: about signing in in yahoo messenger
Yahoo messenger presently is undergoing few changes at the server end. In order to login efficiently I use to run two ping commands. To do so, press on start button click on run button type cmd in the box and hit ok button. In the black window now type exactly the same in the bracket remember brackets are not included in the command (ping www.yahoo.com -t) don't forget to put space after .com before typing -t. -t is hyphen t. repeat this message once more and you will be able to login through messenger. Happy chatting
Posted on Jun 30, 2010
Testimonial: "hey thanks alot...!!!"
My yahoo massager and my yahoo mail is locked how do i fix it
If you are facing any type of technical problem related to your Yahoo account, you can take Yahoo Technical Support to get the easiest solution for your problem.
Here, you can get an expert team who are ready to help their customers 24x7.
They provide user-friendly and effective solutions which can solve the problem quickly.
May 18, 2014 | Computers & Internet
I can not sign in into yahoo messenger.
Did you type your password? or describe exactly by y you can't sign into yahoo? whats the error that tells you when you try sighning in?
Apr 19, 2011 | Yahoo Messenger
Cannot logon
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
when u try this, then download registry cleaner reginout to fix registry errors
Oct 25, 2010 | Yahoo Messenger
Cant sign in
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
download registry cleaner reg in out to solve the problem easily
Sep 14, 2010 | Yahoo Messenger
I kept having the same problems with YM. Every time i tried to sign in, it won't let me sign in. it's about yahoo! messenger troubleshooter and It said " We can't let you sign in". I am sure it was not...
6. Enter your Yahoo! ID and password and click the "Sign In" button. use registry cleaner reg in out to solve registry error for messenger
Sep 13, 2010 | Yahoo Messenger
Why i cant sign in yahoo?
6. Enter your Yahoo! ID and password and click the "Sign In" button. when u try this, then download registry cleaner reg in out to fix registry errors
I have just down load the new messanger and i cant open it or if it do run it shuts down
There have been many issues and bug with the latest Yahoo Messenger update. So i would suggest that you install the version before the latest.
Aug 17, 2010 | Yahoo Messenger
How to receive msgs on my mobile thru yahoo?
Hello.
To receive yahoo messages on your mobile follow these steps:-
1-sing-in in your messenger with your id
2- click on "messenger" on the top
3-in "messenger" click on " preferences"
4- in "preferences" click on "general" on the left side
5-on the botton of "general" window you will see "always sign-in to my mobile when i sing-out of messenger"..click on "Edit Mobile phone"
6-then chose your country and type your mobile number with your country code in the formats given in example below the number box..and then click continue.
7-After doing this you will receive a "code" on your mobile phone
8-enter that mobile code in the confirmation box .
That's it...Enjoy..
Jun 18, 2010 | Yahoo Messenger
I cannot remember my msn messenger password
reset your msn messenger password or windows live password with the steps mentioned below.
  1. On any Windows Live ID site or service sign-in page like https://accountservices.msn.com/ , click Forgot your password?
  2. Verify your Windows Live ID, type the characters you see in the Picture box, and then click Continue.
  3. Click Use my location information and secret answer to verify my identity.
  4. In the Country/Region list, select your country or region, select your state, and then type your ZIP code or postal code if you’re prompted to do so.If you've moved since signing up for your Windows Live ID, use the location information you last provided. If you've provided both a home and work location, enter your home location.
  5. In the Question area in the Secret Answer box, type your answer to the question.
  6. Click Continue.
  7. Enter and confirm a new password, and then click Continue.
  8. If prompted, enter an alternate e-mail address and click Continue, or click Skip to bypass this step.
  9. On the You've changed your password page, click Sign in to Windows Live.
Jun 06, 2009 | Microsoft MSN Messenger Connect Service
Yahoo Messenger Logo
67 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
