Question about ASUS Computers & Internet
Could not proceed to boot - ASUS Computers & Internet
  • 516 Answers
To check your hard disk drive if its detected, turn on your computer and press DEL or F2 to enter BIOS setup. Then go to standard cmos setup and there should be the hard drive detected as Primary or Secondary IDE or SATA. If detected and not loading into windows that case your operating system is corrupted. However If your hard drive is not detected on your bios, turn off your computer and unplug and plug your hard disk drive then turn on your computer start pressing again DEL or F2 then check again your hard drive if it is detected.
If your hard disk drive and cd/dvd rom drive are the same cable you can switch the cable to check if the cable of the hard drive are ok. After you have checked and you found out that the two cables are ok that means you will have to format your computer. But you must backup all your data and files before doing so. Formatting your computer will erase or delete the entire space of the partition which you perform formatting.
Here is the video tutorial on how to format your computer using windows xp
Have a nice day.
Posted on Apr 05, 2011
My sony mbx-223 motherboard hanging when windows booting time,setup time working fine
Dont get exactly your problem but i will try to give some tips.
1. Hanged for about 10 to 15 mins, then proceed to windows? if this is the case, then i would check first the boot sequence, sometimes computer uses network boot.
2. Removed external HDD or flash drive when booting.
3. At the BIOS, try to change the SATA mode to compatibility
Jan 04, 2018 | Sony Computers & Internet
Hello when I turn on my monitor and computer this morning I have a black screen on my envision monitor and the green light keeps blinking do you know how to fix this
Unplug everything from the tower. Including power cord.
Press the power button for 5 secs.
Proceed to connect, power line, mouse, keyboard and monitor
That should reset the power or hibernation mode that you might have issues.
If everything looks normal, proceed to connect your remaining devices.
You must be aware that having a BIOS settings to boot from USB, DVD or USB-FLOPPY might prevent to boot into windows.
Feb 24, 2015 | Envision Computers & Internet
I have Acer 1200 Aspire. When I turn it on, it won't proceed past the initial window. It says boot failure.
It almost sounds like your primary boot disk is incorrectly selected in the BIOS. On older machines, the primary disk on the primary cable had to be the boot disk, but nowadays almost any device can be selected as boot disk. Check your BIOS setting and ensure that the hard disk partition that you have Windows installed on is selected as the first boot device. Otherwise, the system may be looking in the wrong place for the OS and giving the boot error.
Jan 07, 2012 | Acer Aspire X1200-B1601A PC Desktop
I WANT TO RESTORE TO FACTORY SETINGS
If by restore to factory settings you mean reinstall operation system ..you need either a recovery partition or disk ..to use ..or a boot-able disk with the operation system ..
if you have teh recovery partition just press teh key indicated on start for recovery and boot from the partition and proceed for recovery ..or insert the disk ..restart and press any key when asked for to confirm boot from cd ..and proceed with the recovery ..(same way for boot-able disk )
In case it does not boot from disk ..you need to press f12 on start to get to boot menu and select the cd and press enter to force boot from disk ..confirm by any key and go on ..
If you don't have any recovery ..try to borrow or buy or make a boot-able disk ..and install the operation from it ..either by changing boot order in bios or by pressing F12 on start with the disk inside ..select boot from disk and enter ...again press any key to confirm ..and follow instructions ..If you do not know how to do it ..and you are ready to do it anyway...follow one of my services ..and I will guide you by remote assistance to make a disk ..and after that find a way to guide you trough the installing (probably messenger )
Dec 23, 2011 | Computers & Internet
Am trying to format my laptop but i do nt know the proceedeer and is giving me tougth time
It's easy. First make sure the laptop is set to boot from CD drive. If it doesn't ell you how to change the boot sequence on start up then you will have to enter the BIOS on boot (normally either F2 or the delete key)
Change to CD drive as first boot device.
Insert OS disc and press any key to boot from CD.
Done.
May 05, 2010 | HP Computers & Internet
How do i set up duel boot on my medion md8833 pc
When setting up dual boot i.e W2k/Xp install W2k first.
The newest of the OS has to be installed last.FAT or NTSF can be either file system.Use FAT for safety first.
Jul 14, 2008 | Medion Computers & Internet
Re booth system
To resolve this problem, select the Delete restoration data and proceed to system boot menu option which enables the computer to perform a normal restart, instead of performing the restoration process while the computer is in Hibernate mode
source:http://support.microsoft.com/kb/q294427/
Jul 03, 2008 | Microsoft Windows XP Home Edition
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
137 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
