Question about Samsung Digimax S500 Digital Camera
Fi my camera beeps 3 times and switches off also the lens are stuck out it does not go back into the camera bod..im so frustrated because it happened out of nowhere. Thankyou
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2011
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
May 23, 2009 | Samsung Digimax S730 Digital Camera
Camera beeps and shuts off
sorry to hear you are having this issue. well the problem is your lens. the len motors have locked up and are stuck the lens needs replacement. repair run any where from 75.00 and up in most cases.i repair these all of the time.let me know if i can help out any further.
Nov 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera issues:(
I had the same problem, stuck lens, 3 beeps and shutdown. You must get pissed off at the camera first. Then bite the lens, clenching it like pliars (you could probably use pliars too), turn the camera on and immediately start pilling on the lens in the outward direction. The tooth grip unstuck the lens and vot it worked. you can take this solution to the bank.
Aug 20, 2008 | Polaroid i735 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens Wont Come Out & Beeps 3 times.?!?!
exact thing happened to me.
im guessing the lens is sticking out a little bit?
Try lining it back up.
Make the lens lined up.
or push the lens in lightly.
i did it and it worked for me.
Apr 01, 2008 | Polaroid I533P Digital Camera
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
Camera beeps 3 times the shuts off
OMG! so i read all these suggestions and nothing worked or i was just confused..tried the tapping thing but didnt work..so i finally just kept twisting the lens and pushing it in and out..it doesnt really move but i was angry and hoping this was doing something..i turn my camera back on a IT WORKIN AGAIN:) im so happy becuz i was so pissed that i had to buy another camera but i suggest trying this method if the table tapping dont work..OH and my lens didnt look crooked at all so if urs look straight and stilling doing stupid beep thing ,,,try this!
Aug 24, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
