Question about Cameras
The bulb for my Dedo DHL4 light blew it was a 12V 100W bulb so I replaced it with the same type of bulb purchased from calumet sold as a "Dedo Light bulb" but when fitted the bulb doesn't fire up. It flickers and glows a little but doesn't seam to be getting enough power. I ttried bulbs from my other Dedo Lights and they work fine and I tried numerous other new bulbs but the same problem. Totally stumped to why this is happening, any help anyone?
  • Cameras Master
  • 5,412 Answers
This code does not appear to refer to any kind of camera - have you posted this in the correct forum ?
Posted on Jun 13, 2017
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
SOURCE: Flash: PCB Replacement v. New Bulb!?
I just read a few forums about this, and apparently it is a common problem on D50s. The flash pops up with such force that eventually the wiring and/or bracket that pops it up comes loose or breaks, and the camera needs to go in for repair. It probably isn't the bulb.
I'm looking into getting a D80 or better anyway once I have some money saved up, but until then I am using my SB-600. I'd suggest taking it to a repair center if it's still under warranty. If not it will run you around $150-160 to get it fixed, and takes about a month, according to what I read.
Hope this helps!
Posted on Oct 14, 2007
  • 203 Answers
SOURCE: Flash flickers...
i honestly never came across anyone who had a flash replaced usually because most companys flat rate out of warranty repairs at 100-125 dollars-if it's a p series camera it sounds like the flash is dying or the battery is worn out and not supplying proper voltage to allow it to fully fire-i would consider buying a new w series w150 is great or 120- if battery is fine then flash is just shot-even old memory sticks won't work in new models so you also have to buy a new card
Posted on Jul 28, 2008
  • 97 Answers
SOURCE: Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Posted on Sep 05, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
What type of bulb do I need for a Piaggio Zip 50 tail light?
They have seperate stop light bulbs to the tail light which is the uncommon.I think the stop bulbs are 12v 4 watt wedge fit sidelight bulbs,they use them in cars too as sidelight bulbs.the tail light one is a 12v 10 watt bayonet type.
Mar 06, 2015 | 2010 Piaggio Zip 50
Elmo st600
The bulb you need is this one:
100W MR16 12V GZ6.35 BASE 64627 HLX OSRAM
You can try to buy it from here:
http://www.atlantalightbulbs.com/ecart/10Expand.asp?ProductCode=ELMO-VPD100ST600ST800#page=description
May 10, 2014 | Office Equipment & Supplies
I have a model 763RLN where the instructions indicate a max.100W bulb but does not indicate the type of bulb. Is it a special type ?
That is possible,but usually they refer to a regular incondescent bulb with a filament.Screw in type.
You may use a CFL in there,easily. 27 W.
Warm white or cool white one.
100 W. bulbs should be not available,soon.
Jan 18, 2013 | Broan-NuTone N-763RLN Combination Light...
Have you used the LED lights 12 Volt Led Light Bulbs are high energy saving, energy efficient and are small in size. They offer a brighter light than any incandescent bulb and have a low replacement and...
Hello There,
If you plan to have LED lights in your household the easyest thing is to buy the ones, they are made for line voltage (120 V). You have choices for bulb like shape or tubes. The tubes are available for direct replacement (using the existing ballast) ot the line voltage ones (the fixture's wiring should be modified and the ballast needs to be removed). The power saving is constant, by the time passing by you are saving.
Hopefully, this will help you. If you have more specific question, please let me know.
Jul 29, 2017 | Laser Vehicle Parts & Accessories
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
Blew the rear parking lights. Front parking
If they are both gone, you either have a bad ground wire or broken wire. See if you have power back there. The bulbs could be both burnt out.
Oct 15, 2009 | 1993 Mazda 929
Reverse lights fuse blew
hi
check the wire because if the fuse keep blowing there's a wire somewhere on the car that has contact with the frame so everytime you put your car on reverse the 12V wire shortcut on the frame so the fuse blow check all your positive wire and your bulb as well
Good luck
Jun 19, 2009 | 1997 Ford Explorer AWD
Looking for replacement parts for vector spot light
The bulb you are looking for to fit these vector spot lights is an automotive bulb, and H3 with a PK22s base. They come with a cable and a nickle size disk at the base of the bulb. They come in several wattages, eg 55w and 100w. Try the "bulbs.com" website, in their search box type "H3 PK22s" and you will see they have a variety of wattages and voltages. Be sure you buy a 12V for these spot lights. They come with a cable and nickle size disk at the base of the bulb. Hope this helps. From Uncle Ray
Oct 06, 2008 | Camping, Backpacking & Hiking
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
