Manual J Calculations for Residential house 1018 sq. ft. American Standard unit
Please help. My house is one story 1941, two bedroom, one bath. Exterior is stuccoand plaster. Old double hung windows, single pane, old roll insulation in attic. My house is in Whittier, California. I'm thinking of American Standard split unit 14 seer, 80% furnance, single stage. What do you think?
Thank you,
Jerry
  • balance7477 Aug 06, 2008
    Thanks! Just to clarify, my one story stucco, two bedroom, one bath Whittier,CA house is 1,018 sq. ft. It has 13 old double hung windows-single pane, old roll insulation in attic only. The Southern Edison referred license contractor suggest strongly the American Standard split 14 seer, 80% furnance single stage, remove six existing supplies duct work,return and replace all six supplies and return with R-6 duct work, new registers and grill for return. Also he will remove existing package unit on roof and patch roof with plywood and metal, and pull permit, total labor and material is $8,250.00. He says 15 or 16 seer with the 90% variable is a waste of money! The American Standardair.com web reccommends 15 or 16 seer, 90% variable speed furnance.
  • 182 Answers
Without actually doing a load calc it would just be an educated guess.Good choice in equipment though.
Posted on Aug 06, 2008
  • Dave Dobransky Aug 08, 2008
    of course am stan is going to suggest the higher end equipment.It is better.Is it so much better to justify the added expense up front?That's debateable.Good luck.
I need to know how many ton air condenser I need for my house?
400 cfm per ton
1 cfm per square foot
Only calculate living space in home, bedrooms, living area, etc. Do not count hallways, interior closets, etc. Only measure the garage if you are trying to condition that space as well.
If you have an "actual" 7000 sq. ft. home, you will need 17.5 tons.
This is usually achieved with multiple units for a residential building.
Hope this helps!
Jul 19, 2012 | Heating & Cooling
I just had 'goodman gpc1336h41ab' 13.00 seer unit installed , I have a 1250 sq. ft. home and it just doesnt seem to be cooling. The unit runs constantly. So my question is , is my unit big enough...
There are a few variables that determine the size needed to cool your home - the size of your home, type insulation, are just two. I have a 2600 sq ft home - about 1300 sq ft per floor. I choose to cool the entire second floor (bedrooms and baths) and two of the largest rooms on the first floor (kitchen & living room) via flexible ducts from an air handler installed in my attic. My house was built in 1960, and at the time had electric heat. This means it is fully insulated. I replaced all the windows with energy efficient types, and vinyl sided. I installed soffit, ridge and gable vents to keep my attic well ventilated. I can cool my house in Boston, MA to 70 degrees (when it is 85 degrees inside) with a 4 ton unit in a little over an hour with no problem (one ton of cooling is equal to about 12,000 BTUs). Your condenser should not run non-stop. If it is not cooling then it is not a thermostat problem, but could be a gas charge problem. If you haven't paid the contractor in full yet - that may be the reason why. The contractor should know how much cooling you need for the space you have and installed a properly sized unit. Make sure your air filters on the return are clean and replaced regularly. Call the contractor and explain the problem - he should be able to solve it for you very quickly.
Aug 03, 2011 | Heating & Cooling
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
We have an older model Lennox ac model #HS26-461-P and we are trying to find out what the tonnage is. Can you tell me where to look or if you know what it is will you please tell me?
The answer that (TheMobilian) left couldn't be further from the truth, of offense. So you're saying if you have a 1000 sq ft house with 4 bedrooms you'd have 4.5 tons of cooling? That's insane, the compressor in that system would be shot in about 6 months from short cycling. Their are many factors in sizing equipment, but none of them involve how many bedrooms you have. If you don't know how to calculate load from windows and insulation factor, then you can use the old (1 ton per 500-550 sq ft) that will get you close.
Jun 18, 2010 | Heating & Cooling
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Jul 21, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
220 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
