Question about Rinnai Heating & Cooling
Just want to know how many mj is a rinnai turbovector 2000 ng My guess 20 ??? Thanks
3 Suggested Answers
  • 82 Answers
SOURCE: RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
Posted on Mar 29, 2010
  • 6 Answers
SOURCE: rinnai 550f balanced flue heater badge is worn
google the manual
Posted on Oct 07, 2012
What does it take to convert a Rinnai R75LS water heater from propane to natural gas?
Contact Rinnai.
Gas control valve is different, burner is different, burner and gas valve must match, threads are regular instead of reverse, dip switches probably have to be changed since combustion of NG is not as hot. Maybe different sensors. Pressures are lower with NG.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 28, 2013 | Rinnai Water Heaters
Rinnai 551FT Hi I have just got this model
On the data plate on the heater it will say NG for nat gas or LP for bottle gas
Jun 05, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Hi there I am trying to help a friend who has a slightly older version of the Rinnai Timberflame Centrum and he was cleaning the controls on top of the heater and in doing so has pressed one of the...
Sue, have you friend turn the Master ON/OFF Switch to OFF and unplug the heater from the electrical outlet. Wait 15 - 20 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and the heaters electronics should revert back to the original factory settings. From there he can reset it to the settings he had, before the little mishap.
Hope this helps solve the problem. Please let me know. Thanks.
May 17, 2011 | Rinnai Heating & Cooling
Rinnai 550f balanced flue heater badge is worn cant read mj rating
http://www.rinnai.us/customer-support/manuals-literature/ what do i know. rinnai site says model not found. give it a try. energy conversions can be found on line.
Feb 08, 2011 | Heating & Cooling
May 06, 2009 | Heating & Cooling
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
How many kw has my rinnai energy saver 556ftr used when it has used 8170 mj per year
Hi
The answer is 2269 kilowatt hours.
1 kilwatt hour = 3.6 mj
Don't forget to give this solution a rating.
Oct 22, 2008 | Rinnai Heating & Cooling
Temperture bulb
A temp bulb will is only accurate to plus or minus 10 degrees sometimes as much a 20 degrees the ideal place for the bulb is in the intake air flow the bulb comes with a line that is long enough for this application
Oct 07, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Heating & Cooling Logo
161 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
