Question about Epson Stylus RX530 All-In-One InkJet Printer
Yellow and black horizontal lines about an inch apart on entire page of printout. I admit that my last cartridge replacement was not genuine Epson.
  • brianwsmith2 Apr 05, 2011
    Thanks. I advised in my first email that I had been using non-Epson cartridges. But only one set. I have replaced them with the genuine article even though they were not used up. Now, how do I get rid of the lines? Do I just do head cleans til the lines disappear? Or is there a cleaning technique? The printer worked fine until I used non-Epson cartridges. Do you think that the cartridges have damaged the head?
    Regards, Brian.
    Genius:
  • 1,570 Answers
Hi
Horizontal and veritcal line is caused by clogged ink at the print head.
Try removing the ink cartridge into the printer and rub the print head into a plain paper with rubbing alcohol until ink flows and then run the print nozzle for 2-3 times.
I hope it helps you.
Regards
Posted on Apr 06, 2011
  • 4,281 Answers
First make sure your ink cartridges has not any leakage. If your ink cartridge is not genuine then this problem occurs too.Also make sure print head is working fine. Your printer head need repairing.If ink cartridges are fine. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Apr 05, 2011
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Only prints every second line
you do not mention what brand of printer you have.
so...............
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 20, 2010 | Epson Office Equipment & Supplies
Am getting black streaks on my printouts from my EPSON Stylus CX4800. They are darkest on the margins of the paper but the lines are visible across the entire page.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 03, 2010 | Epson Stylus CX4800 All-In-One InkJet...
After every line of black text there is a light blue line.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Black lines interferring with printouts
Not really sure what you mean by lines on your documents, but you could have excessive ink spilled on your printer rollers.or the page bar,,this can usually be remedies by taking the printer apart and carefully cleaning all of the surfaces the paper run against.
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer Problem - Konica Minolta 7450
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
Vertical line on edge of page
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Epson Stylus RX530 All-In-One InkJet Printer Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
