Question about Cyberhome CH-LDV7000 Portable DVD Player
Connect dvd player to television - Cyberhome CH-LDV7000 Portable DVD Player
  • 1,238 Answers
First,look up your portable DVD if there's a audio/video output...next,if your DVD have that,you need a RCA jack for audio/video that connect it to the audio/video input of your TV..
thank you and good luck
Posted on Apr 05, 2011
I need help setting hooking up my DVD player to my hisense tv
There are 3 options for connecting a DVD player to a television. HDMI, Component or VGA. The most common, and best, these days is HDMI which requires 1 cable, called a HDMI cable, between the player and television. These input / output sockets are clearly marked & there is usually about 3 of them on most televisions. HDMI 1, HDMI 2, HDMI 3. The next is component. These consist of 4 separate connections. RED, GREEN, BLUE & YELLOW. Again simply connect like to like. The third (VGA) are RED, WHITE & YELLOW. Same deal, simply connect like to like on player and set. Once one of the connections are made select SOURCE on the television remote and select the connection that you have made. Cheers
Dec 14, 2016 | Televison & Video
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
Correct placing of leads from dvd player into back of TV?
If you are using RCA jacks to connect from the DVD player to the Television (RCA jacks are the connectors that have a white & red colored end for right and left speaker sound and another yellow end for video) connect one end to the back of the DVD player where it says "out going connections" and the other end to the television in the "incoming" connections. Remove your television antenna from the tv to the DVD player. The antenna signal goes to the DVD player and the Dvd player sends the picture outgoing to your tv set.
I hope this helps?
Sep 12, 2011 | Panasonic Televison & Video
How to connect a dvd player to a tv set
Connect the incoming antenna to the DVD player (look for connections on the back of the DVD player for Antenna In). Then connect the Dvd player to the Tv. Use the "out" connections on the back of the DVD player and the "in" connections on the back of the tv. You can use RCA jacks to connect the DVD to the tv, or any other type of connection available. Once the DVD player is connected to the tv, you need to set the incoming source on the television. Click on the source button until you find the one that has a clear picture. Dvd connections are usually listed as "aux 1 or 2" on the tv source choices. You will know when you choose the right one because the picture will come in on the tv.
Hope this helps?
Sep 12, 2011 | Televison & Video
I have rca STB7766G1 converter box can I connect my dvd player
Trial and error. There is no list of products that will work together and how, so when you have situations that come up such as these you have to connect the electronic devices and see what happens. What's worse is that the combination will not always work with the same brands and even if you do get this to work today it might not work tomorrow.
Ok connect the DVD player to the television. Where it says out on the DVD player you connect the connecting cables either yellow, white, and red or green, blue, red, white, red. You connect the other end of them to the television. Put the television on the correct input. Try playing a movie to make sure the dvd player and television are connected properly.
Ok now where it says IN on the DVD player. Connect a yellow, red, and white cable. The other end of that cable connects to the converter box where it says out.
You can also connect the converter box and the dvd player in this way if applicable. If the dvd player has an RF (coax) IN connect a coaxial cable there and connect it to where it says OUT on the converter box.
Then you connect an antenna to where it says ANTENNA IN on the converter box. Now you will have to be able to put your dvd player in input (aux) or turn it to channel 3. You will always leave your dvd player in input (aux) or on channel 3. You will only change channels on the converter box with its remote control or the buttons directly on it. Good luck!
Apr 23, 2011 | Televison & Video
My dvd player only plays back in black and white, no color. any ideas?
If you haven't done so already try connecting a different DVD player (or some other device) to the same part of the television to see if there is color. You can also try changing the cables connecting this dvd player and the television. If there is color on another device then you know that the problem is with the DVD player. If there is color with the same DVD player when you have changed the cables then you'll know that they were the problem. If the television does not play in color no matter what (DVD player or tv channels or anything connected to the television with all different cables) then you'll know it is at fault.
Apr 05, 2011 | Onkyo DR-C500 Multi-disc DVD Player
How can i hook up my player to my tv with no rca inputs
There are adaptors. I bought a Philips brand that allows any dvd player to be connected to any television. You connect the RCA cables to the Philips adaptor from the DVD player then you connect the Philips adaptor to the rf input of the television with a coaxial cable.
Nov 07, 2010 | Mintek DVD-2580 DVD Player
Want to connect dvd player and tv; how can I do this so that I can switch back and forth between tv and dvd player?
Connect the DVD player as you normally would for the inputs that you have available to connect to. Then after that all you have to do is change your input selection to TV/SAT, from whatever input selection your DVD player is connected to.
Dec 26, 2009 | Insignia IS-LCDTV32 32 in. Television
Connecting my DVD Player to my Digital Converter Box
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
JUST MATCH UP THE COLORS.
Feb 01, 2009 | Coby DVD-224 DVD Player
Cyberhome CH-LDV7000 Portable DVD Player Logo
78 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
