I have a hotpoint Aquarius 1100 (WD61) and the door isn't closing tight enough to start the wash.. It looks to me like a faulty connection
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Make sure the ****** is not broken or spring gone/ if need be you may require to fit a new door interlock switch.....Easy to do cost around £18...Parts...Good luck
Posted on Apr 05, 2011
  • davidk160 Apr 05, 2011
    Thank you!!
  • Gerry Harvey
    Gerry Harvey Apr 05, 2011
    your welcome, Door hook s the part to check first.....
Door locked light is flashing hotpoint aquarius washing machine wont start
More than likely the door mechanism is faulty and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Hotpoint Aquarius WD640 Front Load...
Door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Jan 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
I have an Aquarius WD61 washer/dryer. The door will not now open.
No date on this that I can find. Can you move the dial to a different setting? If so, just move it a fraction to see if it will engage. If it does engage, then you will need a new timer, goes under the dial. If it is a computer panel, try resetting it on another load setting and put it on the final spin.
Godd luck
Aug 08, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 washer dryer
probably not door switch, but to access, remove door gasketf rom cabinet in area of door switch and door switch is only held by 2 screws. more likely to be the suppressor capacitor. remove top and look at suppressor - they sometimes go pop
Aug 17, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
