Hi, Here in the company we use a OCE Varionlink 2822C. we got the problem at the moment that no one can use the scanner. the error says: look at the log. when you look at the log you see : wrong login code, but everyone use his/her own user box and login with it.. Can someone help me? Steve,
3 Suggested Answers
SOURCE: Oce tcs 500; system administrator passwork
Old post but will print for future ref - the system administrator password is SysAdm
Posted on Jun 22, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Hi, our oce variolink 2822c
Your machine is made by Konica Minolta. The C3721 code means that your fuser unit has detected an overheat condition. The fuser unit is the assembly that uses heat and pressure to "fuse" the loose toner onto the paper. It is located right where the copies exit the machine. Your are going to need to have your local service company come out and make repairs. You may get advice as to how to reset the code but beware. Since this is an overheat code, if you reset it more than once you can do severe damage to your fuser unit. You may turn a simple and relatively in-expensive repair into a major one.
I would waot if at all possible for the service technician, but I have only worked on Konica Minolta copiers for nearly 28 years now.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Jan 22, 2011
Oce TDS600 Scanner error: 10-501?
It could be either the scanner lamp, or the power supply. If you detect a green glow when you power on the scanner, its the power supply.
Apr 11, 2018 | OCE Office Equipment & Supplies
Oce scanner Error 10516-247
my oce TDS450 scanner has the 10516-247 error. Please help me
Nov 16, 2013 | Office Equipment & Supplies
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
Oce' tds600 error code 10501
This is a scanner error. Clean the mirror with a soft lint free cloth. Be extremely careful as these mirrors are First Surface Mirrors and are easily scratched as well as being expensive. If the mirror and glass are clean, try the scanner power supply.
Dec 12, 2012 | OCE Office Equipment & Supplies
Oce TDS 600 scanner error code 10501
Clean mirror and scanner glass. Be extremely careful cleaning the mirror. Its a First Surface Mirror and extremely expensive.
May 22, 2012 | OCE Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
Hi, our oce variolink 2822c suddenly began to show; "malfunction detected. inform the service representative of the error code", trouble code: c- 3721. Unfortunately service representatives...
WheatlandServices
Jan 22, 2011 | Office Equipment & Supplies
Halftones on Oce Variolink 2822C all in one copier
Unfortunately for you, as color copiers have gotten better, so have the dpi, and there is no low resolution. Have you tried changing the resolution of your original file in an image program like adobe.
Jan 29, 2010 | Office Equipment & Supplies
OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Jul 13, 2009 | OCE Office Equipment & Supplies
43 people viewed this question
k24674
jasbo
jasbo
