Question about KitchenAid KHHS179LSS Convection / Microwave Oven
Microwave Shuts off...
Hey guys....our kitchenaid microwave will shut off automatically about 5 sec after pushing "add minute".....beeps with a morse code like pattern, then magically turns back on. Tonight....same thing happened, but instead of turning back on - the display showed a little man jumping around with the words "no main"..... I had to unplug for a few minutes - then it worked again when I plugged it back in. What's going on???
  • rubiosity Dec 13, 2008
    microwave shows 2 small leds that cycle in downwards pattern - otherwise there is no display - when door is opened the oven light is off, then will turn on - buttons do not work. once door is shut, the microwave will turn on and the carosel will turn for approx 5 seconds - then shut off; it appears that when it does turn on that it generates no microwaves. I can not find manual - any thoughts?
  • KitchenAid Master
  • 9,086 Answers
It sounds like you may have a loose fuse holder or an intermittent part such as one of the thermostats, such as the one mounted on the magnetron.
One thing to try is to cook on the lowest power setting or defrost to see if it runs longer or fails more quickly.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 08, 2008
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Microwave exaust fan starts on its own
There's a humidity sensor in this microwave oven that turns on the fan automatically if it senses an excess amount of humidity (steam from cooking for example) to possibly protect humidity or moisture from building up inside the unit.
Apr 01, 2010 | KitchenAid KHHS179LSS Convection /...
My microwave keeps shutting down and i have to
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, a repeat of your symptoms, as well as the answers to these questions:
When it shuts down, is there anything still on the display?
When it shuts down, does the light still come on when you open the door?
When it shuts down, do you still hear any beeps when you press a pad on the keypad?
Also let us know it if fails while in use or while idle.
Nov 28, 2009 | Magic Chef Microwave Ovens
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Turns off after 3 sec
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Nov 05, 2008 | Panasonic NN-T990SA Microwave Oven
MICROWAVE CONTROL
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KHHS179LSS Convection / Microwave Oven Logo
204 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
