It doesn't light and when it does it goes out soon afterwards. t's a Cannon "The Manor" gas heater
    Brigadier General:
  • 4,736 Answers
It sounds as if the Thermocouple and or Thermopile are starting to fail. In which case they will need to be replaced. In addition, any obstruction in the exhaust vent or the fresh air intake vent will cause the heater to overheat and shut down and will not allow you to relight it, until it cools off.
Hope this helps you troubleshoot the problem.
Posted on Apr 05, 2011
Cannon k38 gas heater: mistakenly turned pilot light on gas heater off. I can't find instruction manuals or any help online. Can you re-ignite the pilot light manually or do I call a service agent?
Anon, To relight pilot check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Light Your Pilot Light Gas Fireplace
Fireplace Pilot Light Tutorial
How To Light The Pilot Light On Gas Heater
Jul 02, 2016 | Water Heaters
Teledyne laars ES125 repair manual
The exchanger alone will run $600 or more, and the headers aren't cheap either. Best to replace the heater. I have had customers do expensive repairs (despite my objections) only to have other expensive parts (T-stats, gas valve, burner tray..) break soon afterward.
Jandy is the closest relative of Teledyne, they used to be affiliated. RayPak has been making reliable heaters for decades.
Nov 23, 2013 | Teledyne Laars Pool & Spa
SR333LP turns on but does not heat
hot surface igniter may not be getting hot enough to ignite the gas
Jun 05, 2013 | Sta Rite Starite 333 Btu Propane Gas...
I have a hayward H250 and the pilot lites easily and quickly as long as the gas control knob is depressed on "pilot" as soon as the knob is released to switch it to "ON" the pilot...
Unit dosn't seem to bve sensing flame. Clean your flame sensor. Its connected to your pilot light assembly usually. Its a metal rod that sits inside the flame. Could also be bad and need replaced. Hope this helps.
May 16, 2011 | Heating & Cooling
I have a Whirlpool gas water heater and the pilot light went out. When I light it it goes out as soon as soon as I release the RESET button.
if it keeps going out, its more likely the thermal coupling is bad and needs replaced. if the coupling goes bad it shuts gas of to heater as a safety precaution. it does not let any gas come out of the main regulator. it works on the principal when the end gets hot it opens the gas valve and lets gas through to burner. replace coupling. have a good day !!
Apr 09, 2011 | Water Heaters
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
