Question about Car Audio & Video
Hi, recently bought a 2002 peugeot 307 and discovered the blaupunkt 5 disc changer doesnt work. The number lights flash, the changer took 1 cd n kept it in there and i cant get it out. Is there an easy-ish way to solve this problem as i am pretty annoyed having spent all my savings on the car?? Thanks.
    Scholar:
  • 83 Answers
For this issue its usually with the unit itself. You have to change the disk player
Posted on Apr 05, 2011
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307
having same problem. faulty after disconection of battery
Jun 03, 2009 | Blaupunkt Car Audio & Video
Flashing lights on cd changer, Peugeot 307!
There are a few variations of this model eg; IDCA09,IDCA04,Fiat & aftermarket units.As already stated these models do suffer from mechanism faults quite a lot.This is due mostly to the complexity of the mechanics.The flashing lights are a classic symptom of a jammed or broken part of the mechanism.They can however be repaired by certain car audio repair centres here in the UK.I'm afraid unless you know what you're doing then just by stripping the mechanism down is unlikely to cure the faults than can occur.
Feb 03, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
hi does it do anythig at all? does it flash?
Mark
Mar 21, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Mar 11, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
141 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
