Mfc-240 paper jam. Have cleared the paper but still comes up "paperjam"
  • 17,130 Answers
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Posted on Apr 05, 2011
Lexmark 5660 paperjam
printer says paper jam no paper in printer i have on pluged it to clear it and its continueing to say paper jam what should i do?
Oct 20, 2012 | Lexmark X5650 All-in-One InkJet Printer
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
Paperjam in a hp photosmart c6380 all in one , how do I open to clear out paperjam ?
I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
Clear Paper Jam
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6380 All-In-One InkJet...
Brother printer mfc 240 error 50?
this error is due to the machine does not work due to a paper jam.Clear the paper jam or may some mechanism not functioning properly check it ....
Dec 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother printer mfc-8860dn
This usually means that it isn't picking up paper at all. Draw and x on the top paper and see if it takes it. You may need a new feed tire or different paper.
Apr 28, 2009 | Brother MFC-8860DN All-In-One Laser...
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
BROTHER MFC 240 C
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Mar 31, 2008 | Brother MultiFunction Center MFC-440CN...
Paper jam - cannot get the paper tray to open
open back side paperjam clear cover. simply push the paperfeedroller towards the inside and pull the paper tray carefully out at the same moment ;-)
Feb 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
32 people viewed this question
k24674
jasbo
jasbo
