Question about KitchenAid KUDD01DSSS Built-in Dishwasher
Top drawer will not stay closed. - KitchenAid KUDD01DSSS Built-in Dishwasher
How do you fix a LG dryer pedestal drawer that won't stay closed and there is nothing behind the drawer to cause the problem?
sounds like a balance issue, you may need to balance the legs on the appliance, try using a leveler on the top of machine
Dec 29, 2016 | LG Washing Machines
Drawer will not stay closed
Hello David, I am JK. I understand that you are having trouble with the drawer staying closed on your pedestal. I would recommend checking to make certain that nothing is caught under the pedestal keeping the drawer from closing properly. If this is not the concern, the strike and/or latch might need to be replaced.
Hope this helps!
Mar 05, 2014 | Electrolux EPWD15IW
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Dishdrawer: Does not start, just beeps once
Some sensors on the unit are telling the controller there is a fault.
Most likely the sensor checking the drawer is open or close is giving a fault. It is likely the drawer has come off the rail.
May 22, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Drawer door won't stay close
Hi Paul Lehto - I understand that the drawer will not close, however may you please provide me the model number so I can assist you better in pinpointing you the information.
Dec 19, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
The top drawer won't stay closed. Keeps opening just by barely touching it. It will run as long as you hold it closed.
There are few possibilities
1. the dishwasher is not sitting correctly on the floor mountings. Could be a slight lean forward. Secure dishwasher per instructions.
2. the drawer has slightly come off the rails. Need to take it front cover off (remove pin on each side) and re-adjust.
3. the drawer seal is not sitting properly. Take the drawer out and check seal on top edge of the housing from inside
Please post a comment to confirm if the solution was helpful
Aug 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
KitchenAid KUDD01DSSS Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
